OpenMV Sensor Shield
$5.00
The OpenMV sensor shield, which leads to the Power supply, 3 servos interface, and 10 io interfaces, 3-wire interface allows you to easily connect other electronic modules.
Description
Description
Pinout
Specifications
Length | 36mm |
Width | 27mm |
Height | 20mm |
Weight | 8g |
Schematic
Circuit diagram (PDF): sensor.pdf
Eagle File: (Sensor.sch sensor.brd)
