代码如下:
import sensor, time, image
# Reset sensor
# Sensor settings
sensor.set_contrast(3)
sensor.set_brightness(-3)
kernel = [-1, -1, -1,\
-1, +9, -1,\
-1, -1, -1]
print(kpts)
img.draw_keypoints(kpts)
time.sleep(1000)
# NOTE: uncomment to load a keypoints descriptor from file
kpts1 = image.load_descriptor("/SWW_F.orb")
kpts2 = image.load_descriptor("/SWW_R.orb")
draw_keypoints(img, kpts1)
if (kpts1 == None):
kpts3 = img.find_keypoints(max_keypoints=150, threshold=10, scale_factor=1.2)
kpts3 = img.find_keypoints(max_keypoints=150, threshold=10, normalized=True)
if (kpts2):
match1 = image.match_descriptor(kpts1, kpts3, threshold=85)
match2 = image.match_descriptor(kpts2, kpts3, threshold=85)
if (match1.count()>12):
img.draw_rectangle(match1.rect())
img.draw_cross(match1.cx(), match1.cy(), size=10)
if (match2.count()>12):
img.draw_rectangle(match2.rect())
img.draw_cross(match2.cx(), match2.cy(), size=10)
# Draw FPS
你好,我想请问一下你在前文定义的kernel是有什么作用吗?
@yuan :grinning_face_with_smiling_eyes:
@kidswong999 感觉你在卖队友哈哈哈
应该是先利用img.morph对图像进行了卷积运算。
