#区域是用哪个颜色阈值threshold识别出来的)。
#print('sum : %d'% len(blobs))
for b in blobs:
#img.draw_rectangle(b.rect()) # rect
img.draw_cross(b.cx(), b.cy()) # cx, cy
img.draw_cross(int(img.width()/2),int(img.height()/2))
#{(1,22),(-3,33),(22222,0),(9999,12),(0,0)}
#data_out = json.dumps(set(data))
uart.writechar(b.cx())
# print(blob[5], blob[6])
# print((img.width()/2), (img.height()/2))
#print('you send:',data_out)
# else:
# print("not found!")
很明显 缩进有问题。
