import sensor, image, time, ml, math, uos, gc
sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((240, 240)) # Set 240x240 window. sensor.skip_frames(time=2000) # Let the camera adjust.
net = None labels = None min_confidence = 0.5
try: # load the model, alloc the model file on the heap if we have at least 64K free after loading net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024))) except Exception as e: raise Exception('Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')
try: labels = [line.rstrip('\n') for line in open("labels.txt")] except Exception as e: raise Exception('Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(e) + ')')
colors = [ # Add more colors if you are detecting more than 7 types of classes at once. (255, 0, 0), ( 0, 255, 0), (255, 255, 0), ( 0, 0, 255), (255, 0, 255), ( 0, 255, 255), (255, 255, 255), ]
def fomo_post_process(model, inputs, outputs): ob, oh, ow, oc = model.output_shape[0]
x_scale = inputs[0].roi[2] / ow
y_scale = inputs[0].roi[3] / oh
scale = min(x_scale, y_scale)
l = [[] for i in range(oc)]
for i in range(oc):
blobs = img.find_blobs(
threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
x = int((x * scale) + x_offset)
w = int(w * scale)
h = int(h * scale)
return lclock = time.clock() while(True): clock.tick()
if i == 0: continue # background class
if len(detection_list) == 0: continue # no detections for this class?
for x, y, w, h, score in detection_list:
print(f"x {center_x}\ty {center_y}\tscore {score}")
print(clock.fps(), "fps", end="\n\n")使用此代码尝试:
# Edge Impulse - OpenMV FOMO Object Detection Example
# Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
sensor.set_framesize(sensor.QQVGA) # Set frame size to QVGA (320x240)
sensor.set_windowing((120, 120)) # Set 240x240 window.
net = None
labels = None
# 列出文件目录及文件信息
print("\nFiles on SD card:")
for f in uos.listdir():
temp = uos.stat(f)
print("file: %s, size: %u bytes" % (f, temp[6]))
print("")
gc.collect()
net = ml.Model("trained.tflite", load_to_fb=True)
print(net)
print(labels)
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
for i in range(oc):
# Slice the output and multiply by 255.0 to ensure float arithmetic
# OpenMV image.Image() from ndarray expects simple memory layout and float32 usually
img_data = outputs[0][0, :, :, i] * 255.0
img = image.Image(img_data)
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
return l
直接复制粘贴过去
这边测试是可以运行的。 第29行报错显示无法识别“trained.tflite”,要么没有文件,要么文件损坏; 你那边首先确保trained.tflite在OpenMV文件目录中,且文件没有损坏
后面的话重新模型部署的要怎么操作修改呢才能运行成功
总不能一直移植过来问吧
重新训练后替换OpenMV里面的模型文件就可以啊,又不用改代码
怎么修改呢
for i in range(oc):
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
net = None
labels = None
# 列出文件目录及文件信息
temp = uos.stat(f)
print("")
gc.collect()
print(labels)
print(net)
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
for i in range(oc):
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
return l
for i in range(oc):
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
依旧上次那个问题
如果4.8.1一直不好使的话,直接退回到4.7的固件运行这个代码就行。 然后等5.0.0的固件发布之后直接更新5.0.0的固件,先不用4.8的固件 固件获取:Release v4.7.0 · openmv/openmv 获取固件后在IDE的工具栏,加载自定义固件烧录即可。firmware.bin
# sensor.set_windowing((240, 240)) # Set 240x240 window.
net = None
labels = None
# 列出文件目录及文件信息
temp = uos.stat(f)
print("")
gc.collect()
print(labels)
print(net)
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
for i in range(oc):
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
return l
4.8.1运行这个代码需要把那个OpenMV的目录里面readme.txt给删除掉,不然会读取这个readme.txt,而不去读取labels.txt,就会造成报错
使用上述我提供的代码,删除readme.txt之后就可以正常运行了。4.8.1的固件
for i in range(oc):
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
这个出错误了
你运行我给的代码,不要运行这个有问题的就行了
