用户使用 OpenMV N6 摄像头运行 AprilTag 识别代码,固件已更新至 v5.0,IDE 为 v4.8.11。代码可正常启动并捕获图像,但在识别到 AprilTag 时发生异常中断,IDE 控制台无任何报错文本输出(无红色错误信息),疑似底层异常、内存溢出或硬件兼容性问题。
sensor.skip_frames(30)
sensor.set_auto_whitebal(False) # must turn this off to prevent image washout...
# f_x 是x的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/3.984*656...
# f_y 是y的像素为单位的焦距。对于标准的OpenMV,应该等于2.8/2.952*488...
# c_x 是图像的x中心位置
# c_y 是图像的y中心位置
f_x = (2.8 / 3.984) *160 # 默认值
f_y = (2.8 / 2.952) *120 # 默认值
c_x = 160 *0.5 # 默认值(image.w * 0.5)
c_y = 120 *0.5 # 默认值(image.h * 0.5)
def degrees(radians):
for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11
img.draw_cross([tag.cx](), [tag.cy](), color = (0, 255, 0))
print_args = (tag.x_translation(), tag.y_translation(), tag.z_translation(),
degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation()))
# 位置的单位是未知的,旋转的单位是角度
print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args)
print(clock.fps())用QVGA或者VGA
用的
QVGA
QQVGA直接跑不起来
VGA帧率太低了,而且识别到也是崩溃
您好
麻烦帮忙解决一下
QVGA
# AprilTags Example
import sensor
import math
sensor.skip_frames(time=2000)
# Note! Unlike find_qrcodes the find_apriltags method does not need lens correction on the image to work.
# What's the difference between tag families? Well, for example, the TAG16H5 family is effectively
# a 4x4 square tag. So, this means it can be seen at a longer distance than a TAG36H11 tag which
# is a 6x6 square tag. However, the lower H value (H5 versus H11) means that the false positive
# rate for the 4x4 tag is much, much, much, higher than the 6x6 tag. So, unless you have a
# reason to use the other tags families just use TAG36H11 which is the default family.
# The AprilTags library outputs the pose information for tags. This is the x/y/z translation and
# x/y/z rotation. The x/y/z rotation is in radians and can be converted to degrees. As for
# translation the units are dimensionless and you must apply a conversion function.
# f_x is the x focal length of the camera. It should be equal to the lens focal length in mm
# divided by the x sensor size in mm times the number of pixels in the image.
# The below values are for the OV7725 camera with a 2.8 mm lens.
# f_y is the y focal length of the camera. It should be equal to the lens focal length in mm
# divided by the y sensor size in mm times the number of pixels in the image.
# c_x is the image x center position in pixels.
# c_y is the image y center position in pixels.
f_x = (2.8 / 3.984) * 160 # find_apriltags defaults to this if not set
f_y = (2.8 / 2.952) * 120 # find_apriltags defaults to this if not set
c_x = 160 * 0.5 # find_apriltags defaults to this if not set (the image.w * 0.5)
c_y = 120 * 0.5 # find_apriltags defaults to this if not set (the image.h * 0.5)
): # defaults to TAG36H11
img.draw_rectangle(tag.rect, color=(255, 0, 0))
# img.draw_cross(tag.cx, tag.cy, color=(0, 255, 0))
print_args = (
tag.x_translation,
tag.y_translation,
tag.z_translation,
degrees(tag.x_rotation),
degrees(tag.y_rotation),
degrees(tag.z_rotation),
# Translation units are unknown. Rotation units are in degrees.
试过啦,还是一样的问题,用QQVGA根本跑不起来的,所以一直是用AVGA
我没有推荐你用QQVGA啊,N6目前不支持QQVGA的分辨率,只能用QVGA或者VGA
您好
这个问题还没解决噢
使用我给你的代码,此代码这边测试可以正常运行
识别到标签就卡住了
sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) # we run out of memory if the resolution is much bigger... sensor.skip_frames(30) sensor.set_auto_gain(False) # must turn this off to prevent image washout... sensor.set_auto_whitebal(False) # must turn this off to prevent image washout... clock = time.clock()
f_x = (2.8 / 3.984) 160 # 默认值 f_y = (2.8 / 2.952) 120 # 默认值 c_x = 160 0.5 # 默认值(image.w 0.5) c_y = 120 0.5 # 默认值(image.h 0.5)
def degrees(radians): return (180 * radians) / math.pi
while(True): clock.tick() img = sensor.snapshot() for tag in img.find_apriltags(fx=f_x, fy=f_y, cx=c_x, cy=c_y): # 默认为TAG36H11 img.draw_rectangle(tag.rect(), color = (255, 0, 0)) img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0)) print_args = (tag.x_translation(), tag.y_translation(), tag.z_translation(), degrees(tag.x_rotation()), degrees(tag.y_rotation()), degrees(tag.z_rotation())) # 位置的单位是未知的,旋转的单位是角度 print("Tx: %f, Ty %f, Tz %f, Rx %f, Ry %f, Rz %f" % print_args) print(clock.fps())
你这运行的也不是我给你的代码啊
