Openmv脱机运行闪烁两下红灯后熄灭
2021-03-29 09:36
G
azuk
#2018.8.2
import sensor, image, time , pyb,json #引入感光元件的模块
from pyb import Timer
from pyb import LED
from machine import I2C
from vl53l1x import VL53L1X
led = pyb.LED(3) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
thresholds = [(27, 67, 19, 91, 45, 76), # 红色
              #(21, 75, 3, -38, 34, 68), # 绿色
               #(36, 100, 45, -54, 26, 124),
                #(55, 70, -28, -10, 33, 57),
              (27, 90, -3, -28, 31, 125),
              (0, 30, 0, 64, -128, 0)]  # generic_blue_thresholds
threshold_index = 1 # 0 for red, 1 for gre9en, 2 for blue
uart_index=0
start=0
current_exposure_time_in_microseconds = sensor.get_exposure_us()
sensor.reset()#初始化感光元件
sensor.set_pixformat(sensor.RGB565)#设置为彩色
sensor.set_framesize(sensor.QVGA)   #320*240 设置图像大小
sensor.skip_frames(time = 2000)#跳过一些帧,等待感光元件稳定
uart = UART(1, 115200)
uart.init(115200, bits=8, parity=None, stop=1, timeout_char=1000) # 使用给定参数初始化
i2c = I2C(2)
distance = VL53L1X(i2c)
#def tick(timer):            # we will receive the timer object when being called
 #   global data
  #  if blobs:
   #     print("Find")
    #    print('you send:',output_str)
     #   uart.write(data)
tim = Timer(4, freq=10)      # create a timer object using timer 4 - trigger at 1Hz
#tim.callback(tick)          # set the callback to our tick function
def find_dir(xzb):
    dire=0
    if (xzb <= 120):
        dire=1
    elif (xzb > 120) and (xzb <185):
        dire=2
    elif (xzb >= 185):
        dire=3
    return dire
def Uart_Receive():   #UART接收 改变框小球的颜色阈值
    global uart_index;
    if uart.any():
       temp_data = uart.readchar()
       if temp_data==1:   #红色
          uart_index=1
          print(temp_data,uart_index)
            uart_index=0
    if start<5:
       start=start+1;
       #clock.tick()
       blobs = img.find_blobs([thresholds[threshold_index]])
           b = max_blob[0] #方框元组
           L = (max_blob[2]+max_blob[3])/2
           l=int(1000/L)
           #x_error = max_blob[5]-img.width()/2   #求横向偏差
           img.draw_rectangle(max_blob[0:4])        # 画矩形
           img.draw_cross(max_blob[5], max_blob[6]) # 画十字
           #发送 小球的(x,y,l,n)
           #x为横坐标,y为纵坐标,l为粗略的距离,n为小球颜色(0:红 1:绿)
           # output_str="%d,%d,%d,%d" % (max_blob.cx(),max_blob.cy(),l,threshold_index) #10进制字符包
           #checkout=0xAA+0x55+0x07+int(max_blob.cx()/2)+max_blob.cy()+l+threshold_index
           fx=find_dir(max_blob.cx());
           xzb=max_blob.cx();
           xzba=int(xzb/100)
           xzbb=int(xzb%100)
           dis=distance.read();
           disa=int(dis/100)
           disb=int(dis%100)
           time.sleep_ms(100)
           output_str="[%d,%d,%d,%d]"%(xzba,xzbb,disa,disb)
           data_out=bytearray([xzba,xzbb,disa,disb])
           uart.write(data_out+'\r\n');
           time.sleep_ms(50)
           led.on()
           #data = bytearray([0xAA,0x55,0x07,int(max_blob.cx()/2),max_blob.cy(),l,threshold_index,0x00,0x00,checkout])#转成16进制
           # uart.write(data)
           # uart.write(output_str)
           #time.sleep_ms(10)
           #led.on()
           print("NO FIND")
           #data = bytearray([0xAA,0x55,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x06])
           data_out=bytearray([0,0])
           time.sleep_ms(50)
           led.off()
    elif start==5:
             l=int(1000/L)
             #发送 小球的(x,y,l,n)
             Uart_Receive()
             time.sleep_ms(50)
             if uart_index!=1:
                time.sleep_ms(1000);
             time.sleep_ms(100)
             disa=int(dis/100)
             disb=int(dis%100)
             xzb=max_blob.cx();
             xzba=int(xzb/100)
             xzbb=int(xzb%100)
             time.sleep_ms(50)
             led.on()
             # uart.write(data)
             #time.sleep_ms(10)
             #led.on()
            print("NO FIND")
            time.sleep_ms(50)
            led.off()
求大佬解答
正常运行没问题 脱机运行就有时行有时不行
2021-03-29 14:19
I
网红小智智 星瞳科技
脱机运行时,是通过USB供电的吗?
2021-03-29 15:49
G
azuk
不是 是外面电池供电
G
azuk
买的你们官方的3.7V供电电池
2021-03-30 17:59
I
网红小智智 星瞳科技
用USB供电试试。
