capture failed:-4
2021-11-06 22:03
N
hmwy
import sensor
import image
import network
import usocket
import sys
import sensor
import image
import network
import usocket
import sys
import math
import pyb
from pyb import LED
# 变量分配区
# 绿色追踪
threshold = [53, 238]
Frame_Cnt = 0
fCnt_tmp = [0, 0]
count = 0
rangefinder = 0
# 局部函数定义区
red_led = LED(1)
green_led = LED(2)
blue_led = LED(3)
ir_led = LED(4)
def get_rangefinder(uart_line):
        if (len(uart_line) < 8):
            return 0xFF
        if(uart_line[0] != 0x59):
            return 0xFF
        if(uart_line[1] != 0x59):
            return 0xFF
        if(uart_line[2] != None and uart_line[3] != None):
            return uart_line[3] * 256 | uart_line[2]
    except:
        return 20
        pass
def ExceptionVar(var):
    data = []
    data.append(0)
    data.append(0)
    if var == -1:
        data[0] = 0
        data[1] = 0
        data[0] = var & 0xFF
        data[1] = var >> 8
    return data
# 串口3 P4 P5 = TX RX
# 串口1 P1 P2 = TX RX
def UART_Send(FormType, Loaction0, Location1, range_finder=0):
    global Frame_Cnt
    global fCnt_tmp
    Frame_Head = [170, 170]
    Frame_End = [85, 85]
    fFormType_tmp = [FormType]
    Frame_Cnt += 1
    if Frame_Cnt > 65534:
        FrameCnt = 0
    fHead = bytes(Frame_Head)
    fCnt_tmp[0] = range_finder & 0xFF
    fCnt_tmp[1] = range_finder >> 8
    # if(range_finder != 0):
    #     fCnt_tmp[1] = range_finder
    fCnt = bytes(fCnt_tmp)
    fFormType = bytes(fFormType_tmp)
    fLoaction0 = bytes(ExceptionVar(Loaction0))
    fLoaction1 = bytes(ExceptionVar(Location1))
    fEnd = bytes(Frame_End)
    FrameBuffe = fHead + fCnt + fFormType + fLoaction0 + fLoaction1 + fEnd
    return FrameBuffe
# main函数区
sensor.set_contrast(3)
#sensor.skip_frames(time = 2000)
uart_Rangefinder = UART(1, 115200)
#文件导入特征点
kpts1 = image.load_descriptor("/desc.orb")
#img = sensor.snapshot()
start = pyb.millis()
while pyb.elapsed_millis(start)<10000:
    kpts2 = img.find_keypoints(max_keypoints=150, threshold=10, normalized=False)
    if kpts2:
        if(match.count()>10):
        P0 = match.x()
        P1 = match.y()
        Type = 306
        print(Type,P0,P1)
        print("no find kpts")
        green_led.off()
        Type = 0xFF
        P0 = -1
        P1 = -1
    uart.write(UART_Send(Type, P0, P1))
    circles = img.find_circles(threshold=4000, x_margin=100,
                           y_margin=100, r_margin=10, r_min=2, r_max=100, r_step=2)
    if circles:
        green_led.on()
        for circle_ in circles:
            img.draw_circle(circle_.x(), circle_.y(),
                        circle_.r(), color=(255, 0, 0))
            img.draw_cross(circle_.x(), circle_.y())
            P0 = circle_.x()
            P1 = circle_.y()
            Type = 202
            print(Type, P0, P1)
        # uart.write(UART_Send(Type, P0, P1, rangefinder))
        print("no find circle")
        green_led.off()
        Type = 0xFF
        P0 = -1
        P1 = -1
2021-11-07 12:39
I
网红小智智 星瞳科技
你的代码没有sensor.reset()
运行hello world有没有问题?
2021-11-07 15:33
N
hmwy
可以运行,但是一个程序可以像上面那样用两个while吗
2021-11-07 16:23
I
网红小智智 星瞳科技
@hmwy 可以,但是下面的死循环永远不会运行。
