你好小助手,因为官网的电机驱动库函数是有四个电平口,但是普通电机驱动板不需要那么多电平端所以我改了库函数,但是发现不能驱动,小助手你看看这个库函数改的有问题吗
from pyb import Pin, Timer
ain1 = Pin('P0', Pin.OUT_PP)
bin1 = Pin('P2', Pin.OUT_PP)
ain1.low()
bin1.low()
pwma = Pin('P7')
pwmb = Pin('P8')
tim = Timer(4, freq=1000)
ch1.pulse_width_percent(0)
ch2.pulse_width_percent(0)
if inverse_left==True:
left_speed=(-left_speed)
if inverse_right==True:
right_speed=(-right_speed)
if left_speed < 0:
ain1.low()
ain1.high()
if right_speed < 0:
bin1.low()
bin1.high()
ch2.pulse_width_percent(abs(right_speed))不清楚你什么电机驱动板,你需要照着真值表对照一下。
