这个是arduino接受数据的
int LED = 13;
int i=0,p=0,m=0;
void setup()
Serial.begin(115200);//模块上电灯快闪,arduino发送指令时需要按住模块上的按键
pinMode(LED,OUTPUT);
void loop()
char ch;
ch = Serial.read();
Serial.print(ch);
// if(ch=='C')
// digitalWrite(LED,HIGH);
// delay(100);
delay(40);
// digitalWrite(LED,LOW);
}这个是openmv测距然后加了串口发送
# Measure the distance
# This example shows off how to measure the distance through the size in imgage
# This example in particular looks for yellow pingpong ball.
yellow_threshold = ( 56, 83, 5, 57, 63, 80)
if len(blobs) == 1:
b = blobs[0]
Lm = (b[2]+b[3])/2
length = K/Lm
output_str="[%d,%d]" % (b[5],b[6]) #方式1
uart.write(output_str+'\r\n')
print(b[5],b[6])
#print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
说明,问号是没有发送数据时的显示。问题:接受数据的前面的几个数据正常,为什么后面的就不对了?求解
