cam rt1062串口不好使,怎么回事啊?
2025-07-19 17:43
C
c2qtfmphpahk
买了这个rt1062,但是串口不好使,用ch340与电脑连上了,引脚和线也没连错,波特率啥的都一样。电脑上收不到数据。而且openmv自己给自己发数据也没接受到。怎么回事啊?
import sensor
from machine import UART
sensor.set_vflip(True)
sensor.set_hmirror(True)
sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
sensor.skip_frames(time=2000)  # Wait for settings take effect.
uart = UART(1, baudrate=9600)  # 假设TX=GPIO17, RX=GPIO16
def send_data_frame(data1, data2):
    frame = bytearray()
    frame.append(0xA3)  # 表头1
    frame.append(0xB3)  # 表头2
    frame.append(data1 & 0xFF)  # 数据1(取低8位)
    frame.append(data2 & 0xFF)  # 数据2(取低8位)
    frame.append(0xC3)  # 表尾
    uart.write(frame)
    print(f"已发送数据帧: {[hex(b) for b in frame]}")
    uart.write(b'\x66')
    time.sleepms(500)
uart = UART(1, baudrate=115200, bits=8, parity=None, stop=1)
    uart.write("Hello\r\n")
    uart.flush()
    if uart.any():
        data = uart.read(timeout=1000)
        print("Received:", data)
    time.sleep(1)
2025-07-19 21:28
C
c2qtfmphpahk
QAQ终于解决了!!
