openmv与arudino mega通讯时,未上电前会一直发送空数据,接收数据时会延迟8位是什么问题?
2025-07-14 09:22
A
xtdf
未开启程序,mega2560收到空
mega2560发送了11次
openmv只收到了3次
openmv代码:
void setup() {
  Serial.begin(9600);
  Serial1.begin(4800);
  pinMode(LED_BUILTIN, OUTPUT);
int cx=0;
void loop() {
  if (Serial1.available() > 0) {
    char received = Serial1.read();
    digitalWrite(LED_BUILTIN, HIGH);
    Serial.print("Received: ");
    Serial.println(received);
    // 简单回声测试
    if(received == 'T') {
      cx++;
      Serial1.write(cx); // 回复R
      Serial.println(cx);
    delay(100);
    digitalWrite(LED_BUILTIN, LOW);
arduino代码
uart = UART(1, 4800, timeout_char= 1000)
uart.read()  # 清空初始化残留数据
    # 发送'T'
    uart.write(b'T')
    print("Sent 'T'")
    # 接收优化:增加重试检测,避免单次错过
    for _ in range(5):  # 连续检测5次(共250ms)
        if uart.any():
            data = uart.read(1)  # 读取所有可用数据(而非固定1字节)
            print("Received:", data)
            break
        time.sleep_ms(50)
        print("No data received")
    time.sleep_ms(500)  # 降低发送频率,避免冲突
插上wifi扩展板后,没有异常:
2025-07-14 09:43
Z
星小瞳xs
使用数据帧的方法传输串口数据即可解决问题
