# Sensor Sleep Mode Example.
# This example demonstrates the sensor sleep mode. The sleep mode saves around
# 40mA when enabled and it's automatically cleared when calling sensor reset().
sensor.skip_frames(time = 3000) # Capture frames for 3000ms.
sensor.sleep(True) # Enable sensor sleep mode (saves about 40mA).我运行这个代码不会出错,建议你返厂维修。
