net = None
labels = None
min_confidence = 0.5
except Exception as e:
counter = [0,0,0,0,0,0,0,0,0,0,0]
clock.tick() # 记录当前时间
img = sensor.snapshot() # 获取图像帧
detections = net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
for obj in detections:
label = labels[obj.classid()]
confidence = obj.confidence()
if confidence > min_confidence:
counter[label] += 1
if counter[label] > 10:
counter[label] = 0
print("%s" % labels[label])
[x, y, w, h] = obj.rect()
img.draw_circle((center_x, center_y), 12, color=colors[i], thickness=2)
img.draw_string(center_x + 20, center_y + 20, labels[i], color=colors[i], scale=1)
你的代码和配套生成的代码不一样啊。
