摄像头
2018-08-03 12:31
J
_13143543271
为什么有时候,在IDE里面看到的图像会泛红色呢,这是什么原因呢
2018-08-03 12:54
X
Yuan
你用的是什么代码?
请运行hello world
http://book.openmv.cc/example/01-Basics/helloworld.html
2018-08-03 15:31
J
_13143543271
不是每次都会出现这种情况,只是偶尔会出现
X
Yuan
请提供出现这种现象的具体代码。
J
_13143543271
import sensor, image, time ,math
red_threshold   = (100, 38, 9, 51, 47, -82)
yellow_threshold = (100, 6, -40, -11, -69, 116)
black_threshold =(0, 25, -31, 26, 25, -44)
sensor.skip_frames(50)
def find_red(blobs):
    max_size = 0
    return max_size
def line_filter_copy(src, dst):
  for i in range(0, len(dst), 1):
      dst[i] = src[i<<1]
def line_filter_bw(src, dst):
      if (src[i<<1] > 200 and src[i<<1] < 255):
          dst[i] = 0xFF
          dst[i] = 0x00
i = 0
max_number = 0
    lines = 0
    img = sensor.snapshot(line_filter = line_filter_copy)
    black_blobs = img.find_blobs([black_threshold])
    red_blobs = img.find_blobs([red_threshold])
    if black_blobs:
        max_blob=find_max(black_blobs)
        #print('sum :', len(blobs))
        if i == 0:
        else :
            pass
        bx_x=max_blob.cx()-160
        by_y=120-max_blob.cy()
        x=math.fabs(bx_x)
        y=math.fabs(by_y)
        if 0 <= x < 10 :
            bx_value = 1
        elif 10 <= x < 100 :
            bx_value = 2
        else :
            bx_value = 3
        if 0 <= y < 10 :
            by_value = 1
        elif 10 <= y < 100 :
            by_value = 2
        else :
            by_value = 3
        b_output_str="x%d%d,y%d%d" % (bx_value,bx_x,by_value,by_y)
        #print('you send:',b_output_str)
        #uart.write(b_output_str+'\r\n')
        print('not found!')
        b_output_str = "0"
    #img = sensor.snapshot()
    #blobs = img.find_blobs([yellow_threshold])
    if red_blobs:
        max_blob=find_max(red_blobs)
        max_number=find_red(red_blobs)
        if i == 1 :
        else :
            pass
        x=math.fabs(x_x)
        y=math.fabs(y_y)
        if 0 <= x < 10 :
            x_value = 1
            x_value = 2
        else :
            x_value = 3
        if 0 <= y < 10 :
            y_value = 1
            y_value = 2
        else :
            y_value = 3
        output_str="x%d%d,y%d%d" % (x_value,x_x,y_value,y_y)
        #print('you send:',output_str)
        #uart.write(output_str+'\r\n')
        #print('not found!')
        output_str = "0"
    #print('max_number:',max_number)
    if max_number > 1250 :
        i = 1
        while(i):
            lines = 0
            if red_blobs:
                if i == 1 :
                else :
                    pass
                x=math.fabs(x_x)
                y=math.fabs(y_y)
                if 0 <= x < 10 :
                    x_value = 1
                    x_value = 2
                else :
                    x_value = 3
                if 0 <= y < 10 :
                    y_value = 1
                    y_value = 2
                else :
                    y_value = 3
                output_str = "0"
            print('you send red:',output_str)
            if max_number < 100 :
                i = 0
            else :
                i = 1
    else :
        print('you send black:',b_output_str)
        i = 0
    max_number = 0
I
网红小智智 星瞳科技
@有点好奇 在 [摄像头](/post/3939) 中说:
改成
sensor.skip_frames(time=2000)
或者更高
