# RTSP Video Server
# This example shows off how to stream video over RTSP with your OpenMV Cam.
# You can use a program like VLC to view the video stream by connecting to the
# OpenMV Cam's IP address.
import network, omv, rtsp, sensor, time
# RTP MJPEG streaming works using JPEG images produced by the OV2640/OV5640 camera modules.
# Not all programs (e.g. VLC) implement the full JPEG standard for decoding any JPEG image
# in RTP packets. Images JPEG compressed by the OpenMV Cam internally may not display.
# FFPLAY will correctly handle JPEGs produced by OpenMV software.
sensor.set_pixformat(sensor.JPEG) # Only supported by the OV2640/OV5640.
sensor.set_framesize(sensor.UXGA)
print("sensor set done")
# Turn off the frame buffer connection to the IDE from the OpenMV Cam side.
# This needs to be done when manually compressing jpeg images at higher quality
# so that the OpenMV Cam does not try to stream them to the IDE using a fall back
# mechanism if the JPEG image is too large to fit in the IDE JPEG frame buffer on the OpenMV Cam.
omv.disable_fb(True)
# Setup Network Interface
network_if = network.WLAN(network.STA_IF)
network_if.active(True)
#network_if.connect('your-ssid', 'your-password')
# Setup RTSP Server
server = rtsp.rtsp_server(network_if)
# For the call back functions below:
# `pathname` is the name of the stream resource the client wants. You can ignore this if it's not
# needed. Otherwise, you can use it to determine what image object to return. By default the path
# name will be "/".
# `session` is random number that will change when a new connection is established. You can use
# session with a dictionary to differentiate different accesses to the same file name.
def setup_callback(pathname, session):
print("Opening \"%s\" in session %d" % (pathname, session))
def play_callback(pathname, session):
print("Playing \"%s\" in session %d" % (pathname, session))
def pause_callback(pathname, session): # VLC only pauses locally. This is never called.
print("Pausing \"%s\" in session %d" % (pathname, session))
def teardown_callback(pathname, session):
print("Closing \"%s\" in session %d" % (pathname, session))
server.register_setup_cb(setup_callback)
server.register_play_cb(play_callback)
server.register_pause_cb(pause_callback)
server.register_teardown_cb(teardown_callback)
# Track the current FPS.
# Called each time a new frame is needed.
def image_callback(pathname, session):
# Markup image and/or do various things.
return img
# Stream does not return. It will call `image_callback` when it needs to get an image object to send
# to the remote rtsp client connecting to the server.
server.stream(image_callback)补充一下,我买的是openMV4 H7 R2 Cam
RTSP本来浏览器就看不了,要用rtsp播放器。
