在巡线小车教程里复制粘贴之后的代码,不知道为什么运行出来的结果和预想的不一样
2020-04-27 19:38
Z
osyq
我运行时显示的图像结果是这样:
按照教程来看,结果应该是这样:
结果应该是所巡的路线成白色,而且图像中间画有条线,但是我运行出的结果是图像中间没有画有线,请问大佬们这是为什么。
请在这里粘贴代码
<main.py>
THRESHOLD = (33, 62, 0, 79, 60, -6) # Grayscale threshold for dark things...
from pyb import LED
import car
rho_pid = PID(p=0.4, i=0)
theta_pid = PID(p=0.001, i=0)
LED(1).on()
LED(2).on()
LED(3).on()
sensor.set_vflip(True)
sensor.set_hmirror(True)
clock = time.clock() # to process a frame sometimes.
if (line):
if line.theta()>90:
theta_err = line.theta()-180
if line.magnitude()>8:
car.run(50+output, 50-output)
car.run(0,0)
car.run(50,-50)
pass
#print(clock.fps())
请在这里粘贴代码
<pid.py>
from pyb import millis
from math import pi, isnan
class PID:
	_RC = 1/(2 * pi * 20)
		self._kp = float(p)
		self._ki = float(i)
		self._kd = float(d)
		self._imax = abs(imax)
		tnow = millis()
		dt = tnow - self._last_t
		output = 0
			dt = 0
			self.reset_I()
		self._last_t = tnow
		output += error * self._kp
				derivative = 0
				self._last_derivative = 0
			self._last_error = error
		output *= scaler
			output += self._integrator
		return output
	def reset_I(self):
		self._integrator = 0
请在这里粘贴代码
<car.py>
from pyb import Pin, Timer
inverse_left=False
inverse_right=False
ain1 = Pin('P0', Pin.OUT_PP)
ain2 = Pin('P1', Pin.OUT_PP)
bin1 = Pin('P2', Pin.OUT_PP)
bin2 = Pin('P3', Pin.OUT_PP)
ain1.low()
ain2.low()
bin1.low()
bin2.low()
pwma = Pin('P7')
pwmb = Pin('P8')
tim = Timer(4, freq=1000)
ch1.pulse_width_percent(0)
ch2.pulse_width_percent(0)
if inverse_left==True:
left_speed=(-left_speed)
if inverse_right==True:
right_speed=(-right_speed)
if left_speed < 0:
ain1.low()
ain2.high()
ain1.high()
ain2.low()
if right_speed < 0:
bin1.low()
bin2.high()
bin1.high()
bin2.low()
2020-04-29 19:14
I
网红小智智 星瞳科技
安装最新的IDE,更新到最新的固件。
