我按照lenet数字识别的视频教程一步步做的,但是总是会弹出这个错误,,我的是openmv4-H7,请问怎么解决?
2020-10-04 10:26
1
utfh
# LetNet Example
import sensor, image, time, os, nn
sensor.set_contrast(3)
sensor.set_windowing((128, 128)) # Set 128x128 window.
sensor.skip_frames(time=100)
sensor.set_auto_gain(False)
# Load lenet network
net = nn.load('/lenet.network')
labels = ['0', '1', '2', '3', '4', '5', '6', '7', '8', '9']
out = net.forward(img.copy().binary([(150, 255)], invert=True))
max_idx = out.index(max(out))
score = int(out[max_idx]*100)
if (score < 70):
score_str = "??:??%"
score_str = "%s:%d%% "%(labels[max_idx], score)
img.draw_string(0, 0, score_str)
print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected
2020-10-04 18:12
I
网红小智智 星瞳科技
cmsis-nn在新的固件里被删除了。
