# Blob Detection and uart transport
red_threshold = (233,255)
led1 =pyb.LED(1)
led2 =pyb.LED(2)
K=1020 #the value should be measured 20*51
K2=0.142
#实际大小=k*直径的像素 k=8cm/51
if blob.pixels() > max_size:
max_size = blob.pixels()
img.binary([red_threshold])
if len(blobs) == 1:
b = blobs[0]
Lm = (b[2]+b[3])/2
length = K/Lm
size=K2*Lm
h = K2*b[3]
w = K2*b[2]
#print("高:%s cm, 宽:%s cm,"% (h,w))
if h>5:led1.on() and led2.on()
elif h<5:led1.off() and led2.off()
output_str="%s" % h #方式1
print('you send:',output_str)
uart.write(output_str+'\r\n')
print('not found!')为什么执行这代码只有led1亮,而led2不亮
elif h<5:led1.off() and led2.off()这句代码逻辑不对。
