RT1062中machine模块配置外部中断的wake参数等于machine.SLEEP时,提示没有这个参数
2025-02-28 17:48
3
gfgy
import sensor
import machine
def ExtInt_IRQHandler(pin):
    Red.on()
    time.sleep_ms(5000)
    Red.off()
sensor.set_framesize(sensor.VGA)  # Set frame size to QVGA (320x240)
sensor.skip_frames(time=2000)  # Wait for settings take effect.
Pin_Ext = machine.Pin("P7",machine.Pin.IN,pull = machine.Pin.PULL_UP)# 初始化外部中断
Pin_Ext.irq(ExtInt_IRQHandler,trigger = machine.Pin.IRQ_RISING,wake=machine.SLEEP)#初始化外部中断,配置唤醒源为Pin
Red = machine.LED("LED_RED")
machine.lightsleep()
    clock.tick()  # Update the FPS clock.
    img = sensor.snapshot()  # Take a picture and return the image.
    img.lens_corr(strength=1.8,zoom=1.0)
    print(clock.fps())  # Note: OpenMV Cam runs about half as fast when connected
2025-02-28 20:08
I
网红小智智 星瞳科技
你是想要IO中断,还是要睡眠?
2025-03-01 09:09
3
gfgy
@kidswong999
我想用IO中断唤醒睡眠
2025-03-11 10:08
I
网红小智智 星瞳科技
OpenMV RT有右上角有一个POWER按键,长按就可以唤醒睡眠。这个按键在左边插针上也有引出,ON/OFF。
2025-03-11 11:13
P
_3xrp
我也遇到一个同样的
