# MJPEG Streaming AP.
# This example shows off how to do MJPEG streaming in AccessPoint mode.
# Chrome, Firefox and MJpegViewer App on Android have been tested.
# Connect to OPENMV_AP and use this URL: http://192.168.1.1:8080 to view the stream.
# Reset sensor
# Set sensor settings
sensor.set_brightness(1)
sensor.set_saturation(1)
# Init wlan module in AP mode.
# Load Haar Cascade
print(face_cascade)
# You can block waiting for client to connect
def start_streaming(s):
client, addr = s.accept()
client.settimeout(2.0)
# Read request from client
data = client.recv(1024)
# Send multipart header
"Server: OpenMV\r\n" \
"Pragma: no-cache\r\n\r\n")
# FPS clock
# Start streaming images
frame = sensor.snapshot()
header = "\r\n--openmv\r\n" \
client.send(header)
client.send(cframe)
#print(clock.fps())
# Find objects.
#image.find_features(cascade, threshold=0.5, scale=1.5),thresholds越大,
#匹配速度越快,错误率也会上升。scale可以缩放被匹配特征的大小。
#在找到的目标上画框,标记出来
# Draw objects
for r in objects:
img.draw_rectangle(r)
# Print FPS.
# Note: Actual FPS is higher, streaming the FB makes it slower.
#print(clock.fps())
if objects:
middle = int((objects[0][0]+objects[0][2])/2)
print(middle)
print('no')
#clock = time.clock()
# Create server socket
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)
# Set server socket timeout
s.settimeout(3)
start_streaming(s)
except OSError as e:
s.close()
print("socket error: ", e)
#sys.print_exception(e)这是我写的代码,而且人脸识别的识别精度比例程差了许多,请问原因?
@19805185968 不同的问题单独发帖子。
@kidswong999 好的,但请先把WIFI无法脱机运行的的问题解决一下好吗,上面是代码
我现在在外地,等回去拿到Wi-Fi扩展板测试一下。
OpenMV的wifi扩展板当作热点时,只能连接一个设备。
你是不是既连了手机,还要连接电脑?
@kidswong999 并没有,电脑端并没有连接OPENMV的热点,还有就是使用5V电源直接供电OPENMV灯明显闪烁的不对,手机上也搜不到热点,我是使用充电宝供电才出现热点,但无法连接!
