买了几个激光测距传感器,但是商家只提供树莓派的教程,我自己尝试过将其转换为openmv的代码,但是没有成功,希望小姐姐可以帮我解决这个问题。树莓派代码如下:
# -*- coding: utf-8 -*-
import serial
import binascii
serial1 = serial.Serial('/dev/ttyUSB1',9600) #/dev/ttyUSB0
if serial1.isOpen() :
print("open success")
else :
print("open failed")
def cl(a):
dat1 = a[0:1]
if dat1 == 'a':
dat1 = 10
elif dat1 == 'b':
dat1 = 11
elif dat1 == 'c':
dat1 = 12
elif dat1 == 'd':
dat1 = 13
elif dat1 == 'e':
dat1 = 14
elif dat1 == 'f':
dat1 = 15
return dat1
def main():
global serial1
time.sleep(0.1)
num=serial1.inWaiting()
if num:
try: #如果读取的不是十六进制数据--
data= str(binascii.b2a_hex(serial1.read(num))) #十六进制显示方法2
if(len(data)>8):
print(data)
dat1 = data[6:7]
dat2 = data[7:8]
dat3 = data[8:9]
dat4 = data[9:10]
#dat5 = data[13:14]
#print("SW:",int(dat1) * 10 + int(dat2))
#print("XW:",int(dat3) * 100 + int(dat4) * 10+ int(dat5))
#SJ = str(int(dat1) * 10 + int(dat2)) + "." + str(int(dat3) * 100 + int(dat4) * 10+ int(dat5))
jl = (((int(cl(dat1)) * 16) + int(cl(dat2))) * 256) + ((int(cl(dat3)) * 16) + int(cl(dat4)))
print(jl)
except: #--则将其作为字符串读取
pass
main()你得发具体的协议的内容。
