基于您提供的弯曲片识别需求,我为您设计了一个完整的OpenMV曲率识别算法框架。这个算法可以识别多个弯曲片,计算弦长和弧高,并最终得出曲率值。
## 完整代码框架:
# 初始化摄像头
sensor.skip_frames(time=2000)
# 校准参数 - 需要根据实际拍摄调整
PIXELS_PER_MM = 5.0 # 每毫米对应的像素数,通过尺子校准
MIN_BLOB_AREA = 500 # 最小斑点面积阈值
MAX_BLOB_AREA = 5000 # 最大斑点面积阈值
# 红色尺子颜色阈值(用于校准)
RED_SCALE_THRESHOLD = (30, 100, 15, 127, 15, 127)
# 弯曲片颜色阈值(需要根据实际颜色调整)
BEND_PIECE_THRESHOLD = (0, 100, -128, 127, -128, 127)
def calibrate_pixels_per_mm(img):
"""通过红色尺子校准像素与毫米的比例"""
# 寻找红色尺子标记
red_blobs = img.find_blobs([RED_SCALE_THRESHOLD], area_threshold=100)
if red_blobs:
# 假设尺子上有已知长度的标记(如1cm)
# 这里需要根据实际尺子特征进行校准
known_length_mm = 10.0 # 已知长度10mm
pixel_length = red_blobs[0].w() # 获取像素长度
return pixel_length / known_length_mm
return PIXELS_PER_MM # 使用默认值
def find_bend_pieces(img):
"""识别并定位所有弯曲片"""
pieces = []
# 二值化处理
binary_img = img.binary([BEND_PIECE_THRESHOLD])
# 寻找所有可能的弯曲片斑点
blobs = binary_img.find_blobs([(100, 255)], area_threshold=MIN_BLOB_AREA,
merge=True, margin=10)
if MIN_BLOB_AREA < blob.area() < MAX_BLOB_AREA:
pieces.append({
'blob': blob,
'contour': blob.min_corners(), # 获取轮廓角点
'center': blob.cx(), blob.cy()
return pieces
def calculate_curvature(contour, pixels_per_mm):
"""计算单个弯曲片的曲率"""
if len(contour) < 3:
return None
# 找到轮廓的端点(最左和最右点)
leftmost = min(contour, key=lambda p: p[0])
rightmost = max(contour, key=lambda p: p[0])
# 计算弦长(像素)
chord_length_px = math.sqrt((rightmost[0]-leftmost[0])**2 +
(rightmost[1]-leftmost[1])**2)
chord_length_mm = chord_length_px / pixels_per_mm
# 找到弧的最高点(距离弦最远的点)
max_distance = 0
arc_top = None
for point in contour:
# 计算点到弦的垂直距离
distance = point_to_line_distance(point, leftmost, rightmost)
if distance > max_distance:
max_distance = distance
arc_top = point
if arc_top is None:
return None
# 计算弧高(像素)
sagitta_px = max_distance
sagitta_mm = sagitta_px / pixels_per_mm
# 计算曲率半径 (R = (c²/8h) + h/2)
if sagitta_mm > 0 and chord_length_mm > 0:
radius_mm = (chord_length_mm**2) / (8 * sagitta_mm) + sagitta_mm / 2
curvature = 1.0 / radius_mm # 曲率 = 1/半径
return {
'chord_length': chord_length_mm,
'sagitta': sagitta_mm,
'radius': radius_mm,
'curvature': curvature
return None
def point_to_line_distance(point, line_start, line_end):
"""计算点到直线的距离"""
x0, y0 = point
x1, y1 = line_start
x2, y2 = line_end
numerator = abs((y2-y1)*x0 - (x2-x1)*y0 + x2*y1 - y2*x1)
denominator = math.sqrt((y2-y1)**2 + (x2-x1)**2)
return numerator / denominator if denominator != 0 else 0
def main():
# 校准像素比例
pixels_per_mm = calibrate_pixels_per_mm(img)
# 识别所有弯曲片
pieces = find_bend_pieces(img)
results = []
for i, piece in enumerate(pieces):
# 计算曲率
curvature_data = calculate_curvature(piece['contour'], pixels_per_mm)
if curvature_data:
results.append({
'piece_id': i,
'center': piece['center'],
**curvature_data
# 在图像上绘制结果
img.draw_circle(piece['center'][0], piece['center'][1], 5, color=(0, 255, 0))
img.draw_string(piece['center'][0]+10, piece['center'][1],
f"R:{curvature_data['radius']:.1f}mm", color=(255, 0, 0))
# 显示FPS
img.draw_string(0, 0, f"FPS: {clock.fps():.1f}", color=(255, 0, 0))
img.draw_string(0, 15, f"Px/mm: {pixels_per_mm:.2f}", color=(255, 0, 0))
# 输出结果到串口
if results:
print("=== Curvature Results ===")
for result in results:
print(f"Piece {result['piece_id']}: "
f"Chord={result['chord_length']:.2f}mm, "
f"Sagitta={result['sagitta']:.2f}mm, "
f"Radius={result['radius']:.2f}mm, "
f"Curvature={result['curvature']:.4f} 1/mm")
time.sleep_ms(100)
if __name__ == "__main__":
main()## 代码各部分详细解释:
## 需要调整的参数:
## 使用步骤:
这个框架应该能够满足您的基本需求,如果需要进一步优化或者遇到具体问题,请提供实际的OpenMV拍摄图片,我可以帮您进行针对性的调整。
如果不采用算弦长和弧高进而计算曲率的办法,有办法可以实现识别弯曲片的曲线然后直接通过曲线得到曲率嘛,毕竟计算过程中也会存在误差。
可以使用“曲线拟合”的方法:建立一个函数,使曲线尽可能和曲线重合,然后可以根据这个函数计算曲率
