OpenMV H7 Plus 部署 Edge Impulse 模型报错
2026-04-08 14:18
J
jquflj1y9gz2
问题概述
用户在 OpenMV H7 Plus 上部署 Edge Impulse 训练的模型时出现报错,具体错误信息尚未提供。
关键信息
  • 硬件:OpenMV H7 Plus
  • 场景:部署 Edge Impulse 导出的模型(如 .tflite 或 .mpy 格式)
  • 问题类型:部署阶段报错(非训练/导出阶段)
待补充信息(后续可编辑更新)
  • 具体报错信息(IDE 控制台文本或截图)
  • 使用的 Edge Impulse 模型导出格式与版本
  • OpenMV IDE 版本及固件版本(如 4.6.0)
  • 部署代码片段(是否使用官方 example / 自定义加载逻辑?)
J
jquflj1y9gz2
2026-04-08 15:11
Z
星小瞳xs
# Edge Impulse - OpenMV FOMO Object Detection Example
# Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
# <https://github.com/openmv/openmv/blob/master/LICENSE>
import sensor, image, time, ml, math, uos, gc
sensor.reset() # Reset and initialize the sensor.\
sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)\
sensor.set_framesize(sensor.QQVGA) # Set frame size to QVGA (320x240)\
sensor.set_windowing((120, 120)) # Set 240x240 window.\
net = None\
labels = None\
min_confidence = 0.5
# 列出文件目录及文件信息
print("\nFiles on SD card:")\
for f in uos.listdir():\
temp = uos.stat(f)\
print("file: %s, size: %u bytes" % (f, temp[6]))\
print("")
gc.collect()\
net = ml.Model("trained.tflite", load_to_fb=True)\
print(net)
labels = [line.rstrip('\n') for line in open("labels.txt")]\
print(labels)
colors = [ # Add more colors if you are detecting more than 7 types of classes at once.\
(255, 0, 0),\
( 0, 255, 0),\
(255, 255, 0),\
( 0, 0, 255),\
(255, 0, 255),\
( 0, 255, 255),\
(255, 255, 255),\
def fomo_post_process(model, inputs, outputs):\
ob, oh, ow, oc = model.output_shape[0]
```javascript
x_scale = inputs[0].roi[2] / ow
y_scale = inputs[0].roi[3] / oh
scale = min(x_scale, y_scale)
l = [[] for i in range(oc)]
for i in range(oc):
    # Slice the output and multiply by 255.0 to ensure float arithmetic
    # OpenMV image.Image() from ndarray expects simple memory layout and float32 usually
    img_data = outputs[0][0, :, :, i] * 255.0
    img = image.Image(img_data)
    blobs = img.find_blobs(
        threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
    for b in blobs:
        rect = b.rect()
        x, y, w, h = rect
        score = (
        x = int((x * scale) + x_offset)
        w = int(w * scale)
        h = int(h * scale)
return l
clock = time.clock()\
while(True):\
```javascript
    if i == 0: continue  # background class
    if len(detection_list) == 0: continue  # no detections for this class?
    for x, y, w, h, score in detection_list:
        print(f"x {center_x}\ty {center_y}\tscore {score}")
Z
星小瞳xs
使用此代码
2026-04-08 15:30
J
jquflj1y9gz2
J
jquflj1y9gz2
这里报错
2026-04-08 15:49
J
jquflj1y9gz2
还是报错
2026-04-08 17:17
Z
星小瞳xs
net = None
labels = None
# 列出文件目录及文件信息
    temp = uos.stat(f)
print("")
gc.collect()
print(labels)
print(net)
    (255,   0,   0),
    (  0, 255,   0),
    (255, 255,   0),
    (  0,   0, 255),
    (255,   0, 255),
    (  0, 255, 255),
    (255, 255, 255),
    for i in range(oc):
        for b in blobs:
            rect = b.rect()
            x, y, w, h = rect
            score = (
            w = int(w * scale)
            h = int(h * scale)
    return l
