OpenMV Cam部署YOLO V8模型后运行main程序自动断连
2026-06-02 09:03
N
n2uu3zb3wrs9
故障描述
按照教程制作并部署YOLO V8模型,连接N6硬件后运行main程序时自动断连,无报错信息。
故障类型
其他
硬件信息
  • 硬件型号:其他(非标准OpenMV4 H7 / H7 Plus / RT)
  • 固件版本:4.8.1
故障代码
# Copyright (c) 2013-2025 OpenMV LLC. All rights reserved.
# <https://github.com/openmv/openmv/blob/master/LICENSE>
# TensorFlow Lite YOLO V8 Example
# This example runs a YOLO V8 person detection model.
# NOTE: This exaxmple requires an OpenMV Cam with an NPU like the AE3 or N6 to run real-time.
import csi
import ml
from ml.postprocessing.ultralytics import YoloV8
# Initialize the sensor.
csi0 = csi.CSI()
csi0.reset()
csi0.pixformat(csi.RGB565)
csi0.framesize(csi.VGA)
csi0.window((416, 416))
# Load YOLO V8 model from ROM FS.
model = ml.Model("/rom/trained.tflite", postprocess=YoloV8(threshold=0.4))
print(model)
# Visualization parameters.
n = len(model.labels)
model_class_colors = [(int(255 *i // n), int(255 *(n - i - 1) // n), 255) for i in range(n)]
    img = csi0.snapshot()
# boxes is a list of list per class of ((x, y, w, h), score) tuples
    boxes = model.predict([img])
    # Draw bounding boxes around the detected objects
    for i, class_detections in enumerate(boxes):
        rects = [r for r, score in class_detections]
        for rect in rects:
            img.draw_rectangle(rect)
        labels = [model.labels[i] for j in range(len(rects))]
        colors = [model_class_colors[i] for j in range(len(rects))]
        ml.utils.draw_predictions(img, rects, labels, colors, format=None)
    print(clock.fps(), "fps")
参考来源
AI云服务生成
硬件图片
2026-06-02 09:30
Z
星小瞳xs
使用最新版本OpenMV IDE 使用此固件:Release Development Release · openmv/openmv 在IDE的工具栏烧录此固件即可
