OpenMV4 H7 运行几秒后摄像头卡死,停止键失效
2026-06-05 20:26
8
88ig4boyz6ml
故障概述
OpenMV Cam 运行几秒后摄像头卡死,IDE 左下角停止键无法响应,只能拔插 USB 重启。项目涉及二维码、物料、色环三类识别任务,此前代码可稳定运行,昨日起突发此问题。
基本信息
  • 故障类型:硬件故障
  • 硬件型号:OpenMV4 H7
  • 固件版本:5.0.0
  • IDE 环境:最新版 OpenMV IDE(未指定版本,但固件为 5.0.0)
故障现象
  • 运行约数秒后画面冻结,无报错提示
  • IDE 停止按钮(●)点击无响应,无法中断脚本
  • 必须物理拔插 USB 才能恢复
相关代码
import sensor
import image
from machine import UART
# 摄像头初始化
sensor.set_windowing((320,240))
sensor.skip_frames(time=3000)
# 固定参数
sensor.set_auto_gain(False, gain_db=18)
sensor.set_auto_exposure(False, exposure_us=40000)
uart = UART(1,115200)
# LAB颜色阈值
red_threshold = (10, 90, 15, 127, -10, 127)
green_threshold = (10, 90, -128, -15, -20, 80)
blue_threshold = (0, 100, -20, 50, -128, -10)
color_dict = {
1: ("RED", red_threshold),
2: ("BLUE", blue_threshold),
3: ("GREEN", green_threshold)
# 全局变量
qr_text = "NONE"
task_list = []
task_index = 0
task_state = 0
detecting = False
detect_start_time = 0
print("SYSTEM START")
# 寻找物料
def find_material(img, threshold):
    blobs = img.find_blobs(
        [threshold],
        pixels_threshold=200,
        area_threshold=200,
        merge=True,
        margin=15
    best_blob = None
    best_score = 0
        # 圆度过滤
        if blob.density() < 0.35:
            continue
        # 长宽比过滤
        ratio = blob.w() / blob.h()
        if ratio < 0.65 or ratio > 1.35:
            continue
        area = blob.area()
        score = area * blob.density()
        if score > best_score:
            best_score = score
            best_blob = blob
    return best_blob
# 寻找色环(新版)
def find_best_ring(img, threshold):
        [threshold],
        pixels_threshold=120,
        area_threshold=120,
        merge=True,
        margin=8
    if not blobs:
        return None
    best_blob = None
    best_score = 0
        # 圆度过滤
        if blob.density() < 0.18:
            continue
        # 长宽比过滤
        if ratio < 0.7 or ratio > 1.3:
            continue
        # 面积过滤
        if blob.area() < 800:
            continue
        x = blob.x()
        y = blob.y()
        w = blob.w()
        h = blob.h()
        # 中心区域检测
        cx = blob.cx()
        cy = blob.cy()
        center_size = int(min(w,h) *0.25)
        center_roi = (
            cx - center_size//2,
            cy - center_size//2,
            center_size,
            center_size
        center_blobs = img.find_blobs(
            [threshold],
            roi=center_roi,
            pixels_threshold=10,
            area_threshold=10
        center_pixels = 0
        for b in center_blobs:
            center_pixels += b.pixels()
        # 中心必须为空
        if center_pixels > center_size * center_size * 0.15:
            continue
        score = blob.area()
            best_score = score
            best_blob = blob
    return best_blob
# 主循环
    # 镜头畸变矫正
    img = img.lens_corr(1.5)
    # 二维码识别
    qrcodes = img.find_qrcodes()
    for code in qrcodes:
        qr_text = code.payload()
        task_list = []
        for c in qr_text:
            if c == '1':
                task_list.append(1)
            elif c == '2':
                task_list.append(2)
            elif c == '3':
                task_list.append(3)
        task_index = 0
        task_state = 0
        detecting = False
        uart.write("QR:{}\r\n".format(qr_text))
        print("QR:", qr_text)
        img.draw_rectangle(code.rect(), color=(255,0,0))
        # UI显示
        img.draw_string(
            10,
            10,
            "QR:" + qr_text,
            color=(255,0,0),
            scale=2
        # 当前任务
        if task_index < len(task_list):
            current_color_id = task_list[task_index]
            color_name, threshold = color_dict[current_color_id]
            img.draw_string(
                10,
                40,
                "TARGET:" + color_name,
                color=(0,255,0),
                scale=2
            # 状态0:物料识别
            if task_state == 0:
                img.draw_string(
                    10,
                    70,
                    "STATE: MATERIAL",
                    color=(255,255,0),
                    scale=2
                blob = find_material(img, threshold)
                if blob:
                    cx = blob.cx()
                    cy = blob.cy()
                    radius = int((blob.w()+blob.h())/4)
                    img.draw_circle(
                        cx,
                        cy,
                        radius,
                        color=(255,255,255),
                        thickness=3
                    img.draw_cross(
                        cx,
                        cy,
                        color=(255,0,0),
                        size=18
                    img.draw_string(
                        cx-30,
                        cy+12,
                        "{},{}".format(cx,cy),
                        scale=1.5
                    uart.write(
                        "MAT:{} X:{} Y:{}\r\n".format(
                            current_color_id,
                            cx,
                            cy
                    now = time.ticks_ms()
                    if not detecting:
                        detecting = True
                        detect_start_time = now
                        duration = time.ticks_diff(
                            now,
                            detect_start_time
                        img.draw_string(
                            10,
                            110,
                            "TIME:{}s".format(
                                int(duration/1000)
                            scale=2
                        if duration >= 3000:
                            detecting = False
                            task_state = 1
                            time.sleep_ms(300)
                    detecting = False
            # 状态1:色环识别
            elif task_state == 1:
                img.draw_string(
                    10,
                    70,
                    "STATE: RING",
                    color=(0,255,255),
                    scale=2
                best_blob = find_best_ring(
                    img,
                    threshold
                if best_blob:
                    x = best_blob.cx()
                    y = best_blob.cy()
                    r = int((best_blob.w() + best_blob.h()) / 4)
                    img.draw_circle(
                        x,
                        y,
                        r,
                        color=(0,255,255),
                        thickness=3
                    img.draw_cross(
                        x,
                        y,
                        color=(0,255,0),
                        size=18
                    img.draw_string(
                        x-30,
                        y+12,
                        "{},{}".format(x,y),
                        color=(0,255,255),
                        scale=1.5
                    uart.write(
                        "RING:{} X:{} Y:{}\r\n".format(
                            current_color_id,
                            x,
                            y
                    if not detecting:
                        detecting = True
                            now,
                            detect_start_time
                        img.draw_string(
                            10,
                            110,
                            "TIME:{}s".format(
                                int(duration/1000)
                            scale=2
                            detecting = False
                            task_index += 1
                            task_state = 0
                            time.sleep_ms(300)
                    detecting = False
    # 全部完成
        img.draw_string(
            50,
            100,
            "ALL DONE",
            color=(0,255,0),
            scale=3
    # FPS显示
    img.draw_string(
        10,
        220,
        "FPS:{:.1f}".format(clock.fps()),
        scale=1.5
硬件图片
2026-06-07 10:41
Z
星小瞳xs
找颜色的程序,5.0.0的固件会报错,改回4.8.1
