运行瞳孔识别示例代码报错(OpenMV 4.8.1固件)
2026-07-05 18:01
8
832w72ppvimb
import display from pyb import Pin,SPI
class LCDTYPE(object) : ST7735X =0 #屏幕128X160 ST7789X =1 #屏幕240x320 ST7796X =2 #屏幕320x480
class SCREEN: def init(self,lcd_type,width=128,height=160,rotate=0): self.lcd_type=lcd_type self.width=width #定义屏幕显示宽 self.height=height #定义屏幕显示高 self.rotate=rotate self.bgr=0x00 self.lcd = display.SPIDisplay(width=self.width,height=self.height) #self.lcd.init(width=self.width,height=self.height)#使用官方库初始化屏幕,配置显示分辨率 #配置显示屏驱动引脚,用于屏幕配置 self.LCD_CS=Pin('P3', Pin.OUT_PP) self.LCD_RST=Pin('P7', Pin.OUT_PP) self.LCD_RS =Pin('P8', Pin.OUT_PP) self.LCD_BACKLIGHT =Pin('P6', Pin.OUT_PP) self.LCD_BACKLIGHT.high() self.spi2= SPI(2,SPI.MASTER,baudrate=72*1000000,phase=1) if (lcd_type==LCDTYPE.ST7789X): self.bgr=0x00 #bgr颜色顺序 self.write_command(0x11) self.write_command(0x36,0x00) self.write_command(0x3A,0x05) self.write_c(0x11) self.write_c(0x21) #LCD 反色 elif (lcd_type==LCDTYPE.ST7796X): self.bgr=0x48 #bgr颜色顺序 self.write_command(0x11) self.write_command(0x36,0x40|0x08) self.write_command(0x3A,0x05) self.write_c(0x11) #配置显示分辨率,可以根据不同的显示需求任意配置,0,0是屏幕显示起始点(影响显示起始位置),240,320屏幕分辨率 self.set_resolution(0,0,self.width,self.height,self.rotate) self.write_command(0x29)
#功能:屏幕写cmd
def write_c(self,c):
    self.LCD_CS.low()
    self.LCD_RS.low()
    self.spi2.send(c)
    self.LCD_CS.high()
#功能:屏幕写data,按byte写
def write_d(self,c):
    self.LCD_CS.low()
    self.LCD_RS.high()
    self.spi2.send(c)
    self.LCD_CS.high()
#功能:屏幕配置寄存器,按数组写
def write_command(self,c,*data):
    self.write_c(c)
    if data:
        for d in data:
            self.write_d(d)
#功能:屏幕配置分辨率属性
def set_resolution(self,x,y,w,h,dir):
    reg_data=0
    if dir==0:
        reg_data = 0xc0|self.bgr
    if dir==1:
        reg_data = 0xa0|self.bgr
    if dir==2:
        reg_data = 0x00|self.bgr
    if dir==3:
        reg_data = 0x60|self.bgr
    self.write_c(0x2a)#设置屏幕长宽像素
    self.write_d(int(x/256))
    self.write_d(x%256)
    self.write_d(int((x+w-1)/256))
    self.write_d((x+w-1)%256)
    self.write_c(0x2b)
    self.write_d(int(y/256))
    self.write_d(y%256)
    self.write_d(int((y+h-1)/256))
    self.write_d((y+h-1)%256)
    self.write_c(0x36)
    self.write_d(reg_data%256)
    self.write_c(0x2C)
def display(self,img):
    if(img.width()>=self.width) and (img.height()>=self.height):
        x=abs(img.width()-self.width)
        y=abs(img.height()-self.height)
        lcd_roi=(int(x/2),int(y/2),self.width,self.height)
        lcd_roi=(0,0,img.width(),img.height())
    self.lcd.write(img,roi=lcd_roi)
    #lcd.display(img)
screen = SCREEN(lcd_type=2,width=480,height=320,rotate=1)
8
832w72ppvimb
这个驱动屏幕驱动程序哪里有问题呀,为啥openmv4plus可以正常让屏幕显示画面,但是N6就不行呀,哪里配置错了吗?
2026-07-06 09:27
Z
星小瞳xs
1、首先需要打开romfs查看是否有对应模型; 2、无对应模型则需要在工具-机器视觉-开放模型库中下载并导入romfs 3、更新固件到5.0.0版本,4.8.1版本不支持完整的romfs使用
2026-07-06 10:15
Z
星小瞳xs
按键的使用请查看英文文档:OpenMV N6 - OpenMV MicroPython 1.28 documentation
2026-07-06 13:06
8
832w72ppvimb
This work is licensed under the MIT license.
Copyright (c) 2013-2023 OpenMV LLC. All rights reserved.
https://github.com/openmv/openmv/blob/master/LICENSE
Hello World Example
Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script!
import sensor,time from screen import SCREEN,screen from pyb import Pin,SPI
sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time=2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS.
while True: clock.tick() # Update the FPS clock. img = sensor.snapshot() # Take a picture and return the image. screen.display(img) print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected # to the IDE. The FPS should increase once disconnected.
8
832w72ppvimb
上面那个是screen.py是屏幕的驱动程序,下面这个是main.py。商家和我说可以在openmv4plus上运行。为啥我用N6就用不了。应该是哪里没配置好,应该就是个小问题,麻烦您帮我看一下
2026-07-06 13:20
Z
星小瞳xs
提供一下LCD显示屏的照片
2026-07-06 13:52
X
xt6a1tfa9w81
那我的那个问题是为什么
X
xt6a1tfa9w81
为什么运行不了会报错
2026-07-06 15:07
Z
星小瞳xs
具体什么问题,你一共问了4个不同的问题,请在对应的问题下回复
2026-07-06 15:21
8
832w72ppvimb
#LCD显示模块 (SPI接口LCD扩展板, 显示YOLO检测画面) lcd = display.SPIDisplay(width=240, height=320, triple_buffer=True) # 初始化LCD
8
832w72ppvimb
这段代码默认的分辨率是多少?
8
832w72ppvimb
是不是168*128
8
832w72ppvimb
我想改为320*240改怎么改。我现在用的屏幕的分辨率为320*240
2026-07-06 15:32
Z
星小瞳xs
image — 机器视觉 — MicroPython 1.22 文档 使用image库将图像缩放到320*240即可: 如此例子将(64,80)缩放到(128,160):
# Copyright (c) 2013-2025 OpenMV LLC. All rights reserved.
# LCD Shield Example
# Note: To run this example you will need a LCD Shield for your OpenMV Cam.
# The LCD shield allows you to view your OpenMV Cam's frame buffer on the go.
import csi
import display
import image
csi0 = csi.CSI()
csi0.reset()
csi0.pixformat(csi.RGB565)
csi0.framesize((64, 80))
# Initialize the lcd screen.
# Note: A DAC or a PWM backlight controller can be used to control the
# backlight intensity if supported:
#  lcd = display.SPIDisplay(backlight=display.DACBacklight(channel=2))
#  lcd.backlight(25) # 25% intensity
# Otherwise the default GPIO (on/off) controller is used.
#  OpenMV Cam M4/M7/H7/H7 Plus -> DAC and GPIO Support
#  OpenMV Cam RT1062 -> GPIO Support
#  OpenMV Cam N6 -> PWM and GPIO Support
lcd = display.SPIDisplay(vflip=True, hmirror=True)
    img = csi0.snapshot()
    lcd.write(csi0.snapshot(), hint=image.CENTER | image.SCALE_ASPECT_KEEP)
2026-07-06 15:45
8
832w72ppvimb
import display
class SCREEN:
    def __init__(self,lcd_type,width=128,height=160,rotate=0):
        self.rotate=rotate
        self.bgr=0x00
        #配置显示屏驱动引脚,用于屏幕配置
            self.write_c(0x11)
            self.write_c(0x11)
    #功能:屏幕写cmd
        self.LCD_CS.low()
        self.LCD_RS.low()
        self.spi2.send(c)
        self.LCD_CS.high()
    #功能:屏幕写data,按byte写
        self.LCD_CS.low()
        self.LCD_RS.high()
        self.spi2.send(c)
        self.LCD_CS.high()
    #功能:屏幕配置寄存器,按数组写
        self.write_c(c)
        if data:
            for d in data:
                self.write_d(d)
    #功能:屏幕配置分辨率属性
        reg_data=0
        if dir==0:
        if dir==1:
        if dir==2:
        if dir==3:
        self.write_d(x%256)
        self.write_c(0x2b)
        self.write_d(y%256)
        self.write_c(0x36)
        self.write_c(0x2C)
        #lcd.display(img)
8
832w72ppvimb
8
832w72ppvimb
# Hello World Example
import sensor,time
    screen.display(img)
8
832w72ppvimb
Z
星小瞳xs
1、OpenMV的例程代码仅支持OpenMV官方扩展板和配件,非OpenMV官方的LCD屏幕无法提供有效支持; 2、N6不使用pyb,N6使用machine库; 3、具体machine库的使用方法具体查看英文文档:OpenMV N6 - OpenMV MicroPython 1.28 documentation
