串口卡死?
2019-03-07 17:08
4
stoz
uart = UART(3,4800, timeout_char=1000)                         # i使用给定波特率初始化
uart.init(4800, bits=8, parity=None, stop=1, timeout_char=1000) # 使用给定参数初始化
GRAYSCALE_THRESHOLD = [(0, 64)]
ROIS = [ # [ROI, weight]
        (0, 0, 1, 1, 1), # You'll need to tweak the weights for your app
        (0, 50, 320, 30, 1), # depending on how your robot is setup.
        (0, 0, 1, 1, 1)
weight_sum = 0
for r in ROIS: weight_sum += r[4]
sensor.set_contrast(3)
sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
sensor.set_framesize(sensor.VGA) # use QQVGA for speed.
sensor.set_auto_gain(False,value=100) # must be turned off for color tracking
a=0
    if kpts:
        print(kpts)
        img.draw_keypoints(kpts)
        time.sleep(1000)
kpts1 = image.load_descriptor("/desc.orb")
def high(x):
    x=x>>8
    return x
def low(x):
    x=x&0xff
    return x
    print(0)
    if uart.any():
        a=int(uart.readchar())
        print(a)
    if a==1:
             print(1)
             if (kpts1 == None):
                 kpts1 = img.find_keypoints(max_keypoints=150, threshold=2, scale_factor=1.2)
                 draw_keypoints(img, kpts1)
                 uart.writechar(0)
                 uart.writechar(0)
                 uart.writechar(0)
                 uart.writechar(0)
                 uart.writechar(0)
                 uart.writechar(0)
                 uart.writechar(0x10)
                 uart.writechar(0x0d)
                 uart.writechar(0x0a)
                 kpts2 = img.find_keypoints(max_keypoints=150, threshold=2, normalized=True)
                 if (kpts2):
                     if (match.count()>10):
                         print(kpts2, "x:%d y:%d"%(match.cx(), match.cy()))
                         mv_x=(int)(match.cx()-160)
                         mv_y=(int)(120-match.cy())
                         Sum=mv_x+mv_y
                         uart.writechar(high(mv_x))
                         uart.writechar(low(mv_x))
                         uart.writechar(high(mv_y))
                         uart.writechar(low(mv_y))
                         uart.writechar(high(Sum))
                         uart.writechar(low(Sum))
                         uart.writechar(0x30)
                         uart.writechar(0)
                         uart.writechar(0)
                         uart.writechar(0)
                         uart.writechar(0)
                         uart.writechar(0)
                         uart.writechar(0)
                     uart.writechar(0)
                     uart.writechar(0)
                     uart.writechar(0)
                     uart.writechar(0)
                     uart.writechar(0)
                     uart.writechar(0)
    if a==2:
             centroid_sum = 0
             for r in ROIS:
                 blobs = img.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=True) # r[0:4] is roi tuple.
                     # Find the blob with the most pixels.
                     largest_blob = max(blobs, key=lambda b: b.pixels())
                     img.draw_rectangle(largest_blob.rect())
                     img.draw_cross(largest_blob.cx(),
                                    largest_blob.cy())
                     centroid_sum += largest_blob.cx() * r[4] # r[4] is the roi weight.
             Mv_x=centroid_sum-160
             Sum=Mv_x
             uart.writechar(high(Mv_x))
             uart.writechar(low(Mv_x))
             uart.writechar(0)
             uart.writechar(0)
             uart.writechar(0x20)
             print(2)
             print("Turn Angle: %f" % Mv_x)
             #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
2019-03-07 18:12
I
网红小智智 星瞳科技
具体什么现象?什么叫做串口卡死?
2019-04-29 16:31
Y
igxs
我也出现了同样的问题,就是openmv接收了几次STM32的数据后,卡在上面不动了,然后自动就弹出来了,需要拔掉USB线重新跑程序,但是也只能接收一会
Y
igxs
@igxs 一会过后 ,直接就又不行了,这个有没有串口中断
2019-04-29 18:21
I
网红小智智 星瞳科技
@igxs 新的问题单独发帖子
