# Blob Detection Example
import car
green_threshold = (76, 96, -110, -30, 8, 66)
size_threshold = 2000
template = image.Image("/cup1.pgm")
blobs = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
x_error = max_blob[0]+max_blob[2]/2-img.width()/2
print("x error: ", x_error)
for b in blobs:
img.draw_cross(int(max_blob[0]+max_blob[2]/2), int(max_blob[1]+max_blob[3]/2)) # cx, cy
print("h_output",h_output)
car.run(18,-18)find_template 返回的只是一个,不是多个,所以不需要find_max
blob = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
if blob:
x_error = blob[0]+blob[2]/2-img.width()/2
h_error = blob[2]*blob[3]-size_threshold
