openmv想实现目标追踪
2024-05-28 22:07
H
mgvl
from pyb import Servo
pan_servo=Servo(1)   #p7
tilt_servo=Servo(2)  #p8
#设置对应的脉宽,分别对应为:允许的最小脉宽:500、允许的最大脉冲:2500、中心/零位置对应的脉宽:500
red_threshold  = (11, 100, 6, 127, -128, 127)
#pid包的函数,设置舵机的pid参数,一般只需要调整p,如果云台抖动的很厉害(速度过快),可以将p调小
sensor.set_vflip(True)
net = None
labels = None
min_confidence = 0.5
except Exception as e:
    (255,   0,   0),
    (  0, 255,   0),
    (255, 255,   0),
    (  0,   0, 255),
    (255,   0, 255),
    (  0, 255, 255),
    (255, 255, 255),
    # of our objects
        for d in detection_list:
            [x, y, w, h] = d.rect()
            pan_error=center_x
            tilt_error=center_y
请问一下这个能控制云台进行追踪吗,我上电之后发现舵机会没有规律乱动,请问一下该怎么改正
