我在把颜色识别和形状识别结合在一起的时候,发现可能是像素点太少的缘故,当距离较远或者角度不正的时候,会识别失败,所以想把QQVGA换成VGA,但是它会报错如下,有人知道怎么才能使用VGA模式吗?我用的7725v3和stm32H7芯片,所以不用担心处理速度的问题。
color_threshold1 = (0, 255, 40, 80, 40, 70)
color_threshold2 = (0, 130, 40, 80, 40, 70)
sensor.set_framesize(sensor.QQVGA) # use QVGA for quailtiy ,use QQVGA for speed.
#扩宽roi
def expand_roi(roi):
# set for QQVGA 160*120
extra = 5
win_size = (160, 120)
(x, y, width, height) = roi
new_roi = [x-extra, y-extra, width+2*extra, height+2*extra]
if new_roi[0] < 0:
new_roi[0] = 0
if new_roi[1] < 0:
new_roi[1] = 0
if new_roi[2] > win_size[0]:
new_roi[2] = win_size[0]
if new_roi[3] > win_size[1]:
new_roi[3] = win_size[1]
return tuple(new_roi)
# pixels_threshold=100, area_threshold=100
blobs = img.find_blobs([color_threshold1], area_threshold=150)
#如果找到了目标颜色
print(blobs)
#迭代找到的目标颜色区域
is_rect = 0
rect_s=0
max_s = -1
new_roi = expand_roi(blob.rect())
for c in img.find_rects():
is_rect = 1
rect_s=c.y()*c.h()
# img.draw_rectangle(x,y,w,h [,color[,thickness=1[,fill=False]]])
if rect_s > max_s:
max_s = rect_s
max_rect = c
if is_rect:
# 如果有对应颜色的矩形 标记外框
img.draw_rectangle(new_roi) # rect
img.draw_rectangle(blob.rect()) # rect
#用矩形标记出目标颜色区域
img.draw_cross(blob[5], blob[6]) # cx, cy
img.draw_rectangle(max_rect.x(), max_rect.y(), max_rect.w(), max_rect.h(),color = (0, 255, 0))
img.draw_rectangle(max_rect.x()-1, max_rect.y()-1, max_rect.w()+2, max_rect.h()+2,color = (0, 255, 0))
VGA模式下是压缩图像,不能进行算法处理。
@kidswong999 嗯,多谢解惑呀
能不能识别多种颜色然后同时画框
@egxs 不同的问题,单独发帖子。
