# MJPEG Streaming AP.
# 这个例子展示了如何在AccessPoint模式下进行MJPEG流式传输。
# Android上的Chrome,Firefox和MJpegViewer App已经过测试。
# 连接到OPENMV_AP并使用此URL:http://192.168.1.1:8080查看流。
import time, sensor, image
import sensor
import image
import network
import usocket
import sys
import sensor
import image
import network
import usocket
import sys
import math
from pyb import LED
Frame_Cnt = 0
fCnt_tmp = [0, 0]
count = 0
rangefinder = 0
# 局部函数定义区
red_led = LED(1)
green_led = LED(2)
blue_led = LED(3)
ir_led = LED(4)
KEY ='1234567890' # wifi密码(必须为10字符)
HOST = '' # 使用第一个可用的端口
PORT = 8080 # 任意非特权端口
# 重置传感器
# 设置传感器设置
sensor.set_brightness(1)
sensor.set_saturation(1)
# 在AP模式下启动wlan模块。
#您可以阻止等待客户端连接
def UART_Send(FormType, Loaction0, Location1, range_finder=0):
global Frame_Cnt
global fCnt_tmp
Frame_Head = [170, 170]
Frame_End = [85, 85]
fFormType_tmp = [FormType]
Frame_Cnt += 1
if Frame_Cnt > 65534:
FrameCnt = 0
fHead = bytes(Frame_Head)
fCnt_tmp[0] = range_finder & 0xFF
fCnt_tmp[1] = range_finder >> 8
# if(range_finder != 0):
# fCnt_tmp[1] = range_finder
fCnt = bytes(fCnt_tmp)
fFormType = bytes(fFormType_tmp)
fLoaction0 = bytes(ExceptionVar(Loaction0))
fLoaction1 = bytes(ExceptionVar(Location1))
fEnd = bytes(Frame_End)
FrameBuffe = fHead + fCnt + fFormType + fLoaction0 + fLoaction1 + fEnd
return FrameBuffe
def ava_filter(x, filt_length):
N = len(x)
res = []
for i in range(N):
if i <= filt_length // 2 or i >= N - (filt_length // 2):
temp = x[i]
sum = 0
for j in range(filt_length):
sum += x[i - filt_length // 2 + j]
temp = sum * 1.0 / filt_length
res.append(temp)
return res
def Findblobs(img):
Type=0xff
p2=-1
p3=-1
greenblobs= img.find_blobs([green])
if greenblobs:
green_led.on()
listblobs=[]
for blob in greenblobs:
listblobs.append(blob.pixels())
maxindex=listblobs.index(max(listblobs))
img.draw_rectangle(greenblobs[maxindex].rect())
Type=25
p2=greenblobs[maxindex].cx()
p3=greenblobs[maxindex].cy()
print("not find")
red_led.on()
return Type,p2,p3
def start_streaming(s):
client, addr = s.accept()
# 将客户端套接字超时设置为2秒
client.settimeout(2.0)
# 从客户端读取请求
data = client.recv(1024)
# 应该在这里解析客户端请求
# 发送多部分head
"Server: OpenMV\r\n" \
"Pragma: no-cache\r\n\r\n")
# FPS clock
# 开始流媒体图像
#注:禁用IDE预览以增加流式FPS。
clock.tick() # 跟踪snapshots()之间经过的毫秒数。
img.histeq(adaptive=True, clip_limit=3)
(Type,p2,p3)=Findblobs(img)
if Type==25 :
green_led.on()
red_led.off()
if(len(listx)<=20 and len(listy)<=20):
listx.append(p2)
listy.append(p3)
del(listx[0])
del(listy[0])
X=ava_filter(listx,20)
Y=ava_filter(listy,20)
p2=sum(X)/len(X)
p3=sum(Y)/len(Y)
img.draw_cross(int(p2),int(p3))
green_led.off()
red_led.on()
uart.write(UART_Send(Type,int(p2),int(p3)))
cframe = img.compressed(quality=35)
header = "\r\n--openmv\r\n" \
client.send(header)
client.send(cframe)
# 创建服务器套接字
# Bind and listen
s.bind([HOST, PORT])
s.listen(5)
# 设置服务器套接字超时
# 关闭并重新打开。在这里使用超时关闭并重新创建套接字。
s.settimeout(3)
start_streaming(s)
except OSError as e:
s.close()
print("socket error: ", e)
#sys.print_exception(e)你8080加了吗?
@kidswong999 加了
先用电脑试一下。
@kidswong999 还是打不开,但是例程是可以打开的
