openmv串口和测距模块
2020-10-11 19:56
I
pm1f
from machine import I2C
from vl53l1x import VL53L1X
from pyb import LED
from pyb import UART, Timer
from pyb import Servo
uart = UART(1,115200)
i2c = I2C(2)
distance = VL53L1X(i2c)
test_state = 1
L = 0
chang = 0
#cir.r = 300
pan_pid=PID(p=0.05, i=0.01, d=0, imax=90) #在线调试PID
tilt_pid=PID(p=0.05, i=0.012,d=0, imax=90)
#pan_pid=PID(p=0.06, i=0.1, d=0.02, imax=100) #脱机运行PID
#tilt_pid=PID(P=0.05, i=0.05, d=0, imax=90)
rect_threshold=(20, 47, 29, 70, 12, 58) #(24, 45, 32, 70, 12, 58)
circle_threshold=(61, 23, 31, 81, 5, 59)
all_thresholds = [(30, 100, 15, 127, 15, 127), # _red_thresholds
                  (30, 100, -64, -8, -32, 32), # _green_thresholds
                  (0, 15, 0, 40, -80, -20)] # _blue_thresholds
sensor.set_auto_gain(False)
def uart_singal():
    buff = 0
    buff = uart.any()
    if buff > 0:
        _data_receive(readchar())
        pass
def _data_receive(data):
    if data == 65:
        test_state = 1
    elif data == 66:
        test_state = 2
        print('error!!!')
def test1_2():
    for r in img.find_rects(threshold = 20000):
        area_rectangle = (r.rect()) #是为了在检测矩形的基础上检测有颜色的矩形
        for blob in img.find_blobs(all_thresholds, pixels_threshold=100, area_threshold=100, merge=True, margin=10,roi = area_rectangle):
            img.draw_rectangle(area_rectangle, color = (0, 255, 0))
            LED(1).toggle()
    for c in img.find_circles(threshold = 2200):
        area_circle = (c.x()-c.r(), c.y()-c.r(), 2*c.r(), 2*c.r())#是为了在检测有圆的基础上检测有颜色的圆
        draw_cir = (c.x(), c.y(), c.r())#画圆的轮廓
        for blob in img.find_blobs(all_thresholds, pixels_threshold=100, area_threshold=100, merge=True, margin=10, roi = area_circle):
            img.draw_circle(draw_cir,  thickness=1, color = (0,255,0),  fill=False)
            LED(3).toggle()
            L = distance.read()-50
            print(L)
            chang = L
            uart.write(chang)
def test3_4():
    pass
        if blob[2]*blob[3]>max_size:
            max_size=blob[2]*blob[3]
    if(test_state == 1):
        test1_2()
    elif(test_state == 2):
        test3_4()
        pass
    uart_singal()
I
网红小智智 星瞳科技
L是int,uart.write只能发送字节串(字符串)。
uart.write(str(L))#转为字符串
