green_threshold = ( 66, 80, -15, 0, -6, 15)
sensor.set_auto_gain(False)
print(type(img))
print(blobs.corners())
for b in blobs:
img.draw_rectangle(b[0:4])
for i in range(4):
print(b[i])
img.draw_cross(b[5], b[6])
uart.write("x:")
uart.write(str(b[5]))
uart.write("y:")
uart.write(str(b[6]))
uart.write("\r\n")
print("x:"+str(b[5])+","+"y:"+str(b[6]))
#print(clock.fps()) # 注意: 你的OpenMV连到电脑后帧率大概为原来的一半Traceback (most recent call last):
File "<stdin>", line 77, in <module>
AttributeError: 'list' object has no attribute 'corners'
MicroPython: v1.15-r32 OpenMV: v4.0.2 HAL: v1.9.0 BOARD: OPENMV4P-STM32H743
Type "help()" for more information.
<font color="#dd0000">print(blobs.corners())</font><br />
我这样使用就会报这样的错
主要是想问大家这个东西该怎么用
find_blobs返回的是列表,里面包含很多个blob对象,尝试用for blob in blobs:来打印每一个blob的conners
