人眼识别示例代码报错 OSError: Could not find the file 如何解决?
2024-12-10 22:43
4
wep1
# Face Eye Detection Example
# This script uses the built-in frontalface detector to find a face and then
# the eyes within the face. If you want to determine the eye gaze please see the
# iris_detection script for an example on how to do that.
import sensor
import image
# Reset sensor
# Sensor settings
# Load Haar Cascade
eyes_cascade = image.HaarCascade("eye", stages=24)
print(face_cascade, eyes_cascade)
# FPS clock
    # Capture snapshot
    # Find a face !
    objects = img.find_features(face_cascade, threshold=0.5, scale_factor=1.5)
    # Draw faces
    for face in objects:
        img.draw_rectangle(face)
        # Now find eyes within each face.
        # Note: Use a higher threshold here (more detections) and lower scale (to find small objects)
        eyes = img.find_features(
            eyes_cascade, threshold=0.5, scale_factor=1.2, roi=face
        for e in eyes:
            img.draw_rectangle(e)
    # Print FPS.
    # Note: Actual FPS is higher, streaming the FB makes it slower.
