运行代码之后红灯常亮然后卡住
2025-07-29 20:38
C
a3un
运行这个代码之后openMV一开始可以运行之后就卡住了
# Hello World Example
import sensor
from machine import UART, LED
sensor.set_framesize(sensor.QVGA)  # Set frame size to QVGA (320x240)
sensor.skip_frames(time=2000)  # Wait for settings take effect.
black = (32, 100, -128, 127, -128, 127)
uart = UART(1, 9600)
LED("LED_RED").on()
while uart.any()==0:
    continue
LED("LED_BLUE").on()
LED("LED_GREEN").on()
    img = sensor.snapshot()  # Take a picture and return the image.
    blobs = img.find_blobs([black], invert=True, roi = [0,100,320,48])
    if len(blobs) == 1:
        img.draw_rectangle([0,100,320,48])
        img.draw_rectangle(blobs[0][0:4], color = (0, 255, 0))
        uart.write('#'+str(blobs[0].cx())+'$')
        print('#'+str(blobs[0].cx())+'$')
    elif len(blobs) == 0:
        uart.write('S')
        print('S')
        LED("LED_GREEN").off()
            continue
然后就一直显示红灯运行事例中的代码酒不会出现这种情况
2025-07-31 10:52
Z
星小瞳xs
是第一个while的问题,注释掉后可以正常运行:
# while uart.any()==0:
# continue
2025-07-31 22:51
C
a3un
@uzbd OK感谢
