# LetNet Example
sensor.set_contrast(3)
sensor.set_windowing((28, 28))
sensor.skip_frames(time = 2000) # Wait for settings take effect.
sensor.set_auto_gain(False)
out = img.invert().find_number()
if out[1] > 3.0:
print(out[0])
#print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected
# to the IDE. The FPS should increase once disconnected.image对象中没有find_number吗?
https://book.openmv.cc/example/25-Machine-Learning/nn_lenet.html
