sensor.set_windowing((640, 80))
sensor.set_auto_gain(False)
uart = UART(3,4800)
def barcode_name(code):
return "EAN2"
return "EAN5"
return "EAN8"
return "UPCE"
return "ISBN10"
return "UPCA"
return "EAN13"
return "ISBN13"
if(code.type() == image.I25):
return "I25"
return "DATABAR"
return "DATABAR_EXP"
return "CODABAR"
return "CODE39"
return "PDF417"
return "CODE93"
return "CODE128"
codes = img.find_barcodes()
for code in codes:
img.draw_rectangle(code.rect())
print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps())
print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args)
if not codes:
print("FPS %f" % clock.fps())
uart.write( code.payload)
time.sleep(1000)
代码格式不对,看不了
新人先看一下 必看:玩转星瞳论坛了解一下图片上传,代码格式等问题。
