用edge impulse训练,就两种模型,训练出来就8帧,好低啊怎么让他高
net = None
labels = None
min_confidence = 0.5
except Exception as e:
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
# of our objects
for d in detection_list:
[x, y, w, h] = d.rect()
print(clock.fps(), "fps", end="\n\n")8帧不错了,正常。
