openmv识别到一个目标后怎么让openmv后面只识别这一个目标?
2023-05-14 15:57
J
nfca
import sensor, image, time, os, tf, math, uos, gc,ustruct
uart = UART(3, 19200)
net = None
labels = None
min_confidence = 0.5
except Exception as e:
    (255,   0,   0),
    (  0, 255,   0),
    (255, 255,   0),
    (  0,   0, 255),
    (255,   0, 255),
    (  0, 255, 255),
    (255, 255, 255),
    # of our objects
    R = net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])
    for i, detection_list in enumerate(R):
        for d in detection_list:
            [x, y, w, h] = d.rect()
            if (center_x < 160 ):
                Lor=1
                Lor=2
            print(Lor)
            output_L = json.dumps(Lor)
            img.draw_circle((center_x, center_y, 33), color=colors[i], thickness=2)
            sj=bytearray([i,center_x])
            # uart.write(sj)
            uart.write(labels[i] +  ' ' + output_L +'\r\n')
2023-05-15 17:46
I
网红小智智 星瞳科技
没有跟踪的算法,你可以根据上次的坐标,找到这次的离得最近的那个。
