# Measure the distance
# This example shows off how to measure the distance through the size in imgage
# This example in particular looks for yellow pingpong ball.
yellow_threshold = (2, 85, -128, 127, 18, 64)
sensor.set_framesize(sensor.FHD) #【ov5640】
blobs = img.find_blobs([yellow_threshold], x_stride=2, y_stride=1)
if len(blobs) == 1:
b = blobs[0]
Lm = (b[2]+b[3])/2
length = K/Lm
print(length)
#print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
以为是内容的问题,插入了sd新卡,仍旧报错。
请大佬不吝指点。谢谢
ide 3.0.3,windows7 ,openmv4 H7
硬件为OpenMV4 H7 PLUS
我是用OpenMV4 H7 Plus,固件4.4.2,没有出现错误。
@kidswong999
感谢回复。
没有改动程序。没有错误。不知道是不是以后还会抽筋。
