问题描述:
openmv4H7在edgeimpulse网站上训练手部识别,图像分辨率96*96,训练好的文件导入openmv4H7中,在OpenMVIDE中运行代码报错Exception: Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (Failed to allocate tensors),这是怎么回事???
# Edge Impulse - OpenMV FOMO Object Detection Example
# Copyright (c) 2013-2024 OpenMV LLC. All rights reserved.
import sensor, image, time, ml, math, uos, gc
net = None
labels = None
min_confidence = 0.5
net = ml.Model("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64*1024)))
except Exception as e:
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
ob, oh, ow, oc = model.output_shape[0]
x_scale = inputs[0].roi[2] / ow
y_scale = inputs[0].roi[3] / oh
scale = min(x_scale, y_scale)
l = [[] for i in range(oc)]
for i in range(oc):
blobs = img.find_blobs(
threshold_list, x_stride=1, y_stride=1, area_threshold=1, pixels_threshold=1
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
x = int((x * scale) + x_offset)
w = int(w * scale)
h = int(h * scale)
return l
if i == 0: continue # background class
if len(detection_list) == 0: continue # no detections for this class?
for x, y, w, h, score in detection_list:
print(f"x {center_x}\ty {center_y}\tscore {score}")
请在这里粘贴代码用这个代码
net = None
labels = None
net = ml.Model("trained.tflite", load_to_fb=True)
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
for i in range(oc):
for b in blobs:
rect = b.rect()
x, y, w, h = rect
score = (
w = int(w * scale)
h = int(h * scale)
return l
