为什么使用openmv求寻迹偏差值的时候脱机运行和连电脑时得到的值不同,连电脑的时候很完美,脱机错误很大
from pyb import UART,LED
write_threshold=(0, 19, 28, -33, 122, -2)
sensor.set_windowing((504,480))
sensor.set_vflip(True)
sensor.set_hmirror(True)
quyu=[278,278,278,278,278,278,278,278,278,278]
LED(1).on()
LED(2).on()
LED(3).on()
lx=0
x=0
k=0
t=0
m=0
last=0
l=0
uart=UART(3,115200)
if blob.pixels()>max_size:
max_size = blob.pixels()
img=sensor.snapshot ()
for n in range(0,10):
blobs = img.find_blobs([write_threshold],roi=[193,480-48*(n+1),172,48],x_stride=20,y_stride=20,x_stride=400)
img.draw_rectangle((193,480-48*(n+1),172,48),color=(231,188,105))
max_blob=find_max(blobs)
quyu[n]=max_blob.cx()
m+=1
if m>=2:
k+=(max_blob.cx()-lx)/48
lx=max_blob.cx()
x=x+quyu[n]
blobs = img.find_blobs([write_threshold],roi=[53,80,100,80])
t+=max_blob.cx()
blobs = img.find_blobs([write_threshold],roi=[53,240,452,80])
l=max_blob.w()
if m!=0:
last=x/10+k*30/m
if l>200:
t=666
if k>1:
k=1
if k<-1:
k=-1
print(last-278,t)
output_str="%.3d, %.3d" % (last,t)
lx=0
x=0
k=0
t=0
m=0
uart.write('\n'+output_str+'\r')
img.draw_rectangle((53,80,100,80),color=(231,188,105))
img.draw_rectangle((53,240,452,80), color=(231,188,105))@kidswong999
LED(1).on()
LED(2).on()
LED(3).on()
lx=0
x=0
k=0
t=0
m=0
last=0
l=0
uart=UART(3,115200)
m+=1
if m>=2:
lx=max_blob.cx()
x=x+quyu[n]
t+=max_blob.cx()
l=max_blob.w()
if m!=0:
last=x/10+k*30/m
if l>200:
t=666
if k>1:
k=1
if k<-1:
k=-1
print(last-278,t)
lx=0
x=0
k=0
t=0
m=0
img.draw_rectangle((53,240,452,80), color=(231,188,105))代码没看出来有什么问题,你是不是环境光源不一致?
