# Barcode Example
# This example shows off how easy it is to detect bar codes using the
# OpenMV Cam M7. Barcode detection does not work on the M4 Camera.
sensor.set_framesize(sensor.VGA) # High Res!
sensor.set_windowing((640, 80)) # V Res of 80 == less work (40 for 2X the speed).
sensor.set_auto_whitebal(False) # must turn this off to prevent image washout...
# Barcode detection can run at the full 640x480 resolution of your OpenMV Cam's
# OV7725 camera module. Barcode detection will also work in RGB565 mode but at
# a lower resolution. That said, barcode detection requires a higher resolution
# to work well so it should always be run at 640x480 in grayscale...
def barcode_name(code):
return "EAN2"
return "EAN5"
return "EAN8"
return "UPCE"
return "ISBN10"
return "UPCA"
return "EAN13"
return "ISBN13"
if(code.type() == image.I25):
return "I25"
return "DATABAR"
return "DATABAR_EXP"
return "CODABAR"
return "CODE39"
return "PDF417"
return "CODE93"
return "CODE128"
codes = img.find_barcodes()
for code in codes:
img.draw_rectangle(code.rect())
print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps())
print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args)
if not codes:
print("FPS %f" % clock.fps())
你是用的是哪个版本的固件,我用3.9.4没问题。
是传感器的问题吗
@kidswong999
把这两行注释掉。
@kidswong999 已解决 谢谢
