XGA连续识别条形码经常发生卡死现象?
2021-05-25 15:00
F
mesi
运行一段时间就发生卡死现象,然后直接直接断连,图为断连前打印数据
功能是同时识别二维码和条形码,如果画面有多个条形码,就取最上面一个。
# Barcode Example
# This example shows off how easy it is to detect bar codes using the
# OpenMV Cam M7. Barcode detection does not work on the M4 Camera.
from pyb import Pin, Timer
# 50kHz pin6 timer2 channel1
light = Timer(2, freq=50000).channel(1, Timer.PWM, pin=Pin("P6"))
light.pulse_width_percent(50) # adjust light 0~100
sensor.set_framesize(sensor.XGA) # High Res!
sensor.set_windowing((1000, 400))# V Res of 80 == less work (40 for 2X the speed).
# Barcode detection can run at the full 640x480 resolution of your OpenMV Cam's
# OV7725 camera module. Barcode detection will also work in RGB565 mode but at
# a lower resolution. That said, barcode detection requires a higher resolution
# to work well so it should always be run at 640x480 in grayscale...
def barcode_name(code):
        return "EAN2"
        return "EAN5"
        return "EAN8"
        return "UPCE"
        return "ISBN10"
        return "UPCA"
        return "EAN13"
        return "ISBN13"
    if(code.type() == image.I25):
        return "I25"
        return "DATABAR"
        return "DATABAR_EXP"
        return "CODABAR"
        return "CODE39"
        return "PDF417"
        return "CODE93"
        return "CODE128"
    codes = img.find_barcodes()
    codeh = 0
    y = 10000000
    print(len(codes))
    if (len(codes)>1):
        for code in codes:
            img.draw_rectangle(code.rect())
            y1 =code.y()
            print(y1)
            if(y1<y):
                y = y1
                codeh = code
        if(codeh != ""):
            print_args = (barcode_name(codeh), codeh.payload(), (180 * codeh.rotation()) / math.pi, codeh.quality(), clock.fps())
            print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args)
        for code in codes:
            codeh = code
    #img.lens_corr(1.8) # strength of 1.8 is good for the 2.8mm lens.
        print(code)
    if not codes:
        print("FPS %f" % clock.fps())
F
mesi
图一为卡死后自动断连的情况
2021-05-25 18:40
I
网红小智智 星瞳科技
我运行没有发现错误,你检查一下是不是USB接口松了。
2021-05-26 17:13
F
mesi
@kidswong999 现在测试第一次12分钟就断连 重新连接后 几分钟就断连,是不是xga大画面传输 导致温度太高了,然后自己断了 。
F
mesi
@kidswong999 因为摸着很烫
2021-05-27 11:37
F
mesi
@kidswong999
检查了usb接口,然后使用例程里面的条形码 改为xga画质,还是运行一段时间就卡死
# Barcode Example
#sensor.set_windowing((640, 80)) # V Res of 80 == less work (40 for 2X the speed).
        return "EAN2"
        return "EAN5"
        return "EAN8"
        return "UPCE"
        return "ISBN10"
        return "UPCA"
        return "EAN13"
        return "ISBN13"
        return "I25"
        return "DATABAR"
        return "CODABAR"
        return "CODE39"
        return "PDF417"
        return "CODE93"
        return "CODE128"
    for code in codes:
        print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps())
    if not codes:
2021-05-27 18:38
I
网红小智智 星瞳科技
@mesi 那你联系售后寄回维修,让售后复现问题。
