模板识别和颜色识别能串起来一起用吗
2018-08-05 14:36
A
_15924974027
另外想问一下,模板识别想识别0到9,但是它会报错,说是请降低像素,减少在运行的数量,降低像素还是不能解决。最后减少了3个数字它才能正常的运行,这怎么解决?
2018-08-05 16:36
I
网红小智智 星瞳科技
请发具体的代码,与报错提示。
2018-08-05 17:25
A
_15924974027
import time, sensor, image
# Reset sensor
# Set sensor settings
# Load template.
template0 = image.Image("/0.pgm")
template4 = image.Image("/4.pgm")
template5 = image.Image("/5.pgm")
template6 = image.Image("/6.pgm")
template7 = image.Image("/7.pgm")
template8 = image.Image("/8.pgm")
template9 = image.Image("/9.pgm")
# Run template matching
r0 = img.find_template(0, 0.70, step=4, search=SEARCH_EX)
if r0:
print('0')
r1 = img.find_template(1, 0.70, step=4, search=SEARCH_EX)
if r1:
print('1')
r2 = img.find_template(2, 0.70, step=4, search=SEARCH_EX)
if r2:
print('2')
r3 = img.find_template(3, 0.70, step=4, search=SEARCH_EX)
if r3:
print('3')
r4 = img.find_template(4, 0.70, step=4, search=SEARCH_EX)
if r4:
print('4')
r5 = img.find_template(5, 0.70, step=4, search=SEARCH_EX)
if r5:
print('5')
r6 = img.find_template(6, 0.70, step=4, search=SEARCH_EX)
if r6:
print('6')
r7 = img.find_template(7, 0.70, step=4, search=SEARCH_EX)
if r7:
print('7')
r8 = img.find_template(8, 0.70, step=4, search=SEARCH_EX)
if r8:
print('8')
r9 = img.find_template(9, 0.70, step=4, search=SEARCH_EX)
if r9:
print('9')
2018-08-05 17:33
A
_15924974027
# Reset sensor
# Load template.
r0 = img.find_template(template0, 0.70, step=4, search=SEARCH_EX)
if r0:
print('0')
r1 = img.find_template(template1, 0.70, step=4, search=SEARCH_EX)
if r1:
print('1')
r2 = img.find_template(template2, 0.70, step=4, search=SEARCH_EX)
if r2:
print('2')
r3 = img.find_template(template3, 0.70, step=4, search=SEARCH_EX)
if r3:
print('3')
r4 = img.find_template(template4, 0.70, step=4, search=SEARCH_EX)
if r4:
print('4')
r5 = img.find_template(template5, 0.70, step=4, search=SEARCH_EX)
if r5:
print('5')
r6 = img.find_template(template6, 0.70, step=4, search=SEARCH_EX)
if r6:
print('6')
r7 = img.find_template(template7, 0.70, step=4, search=SEARCH_EX)
if r7:
print('7')
r8 = img.find_template(template8, 0.70, step=4, search=SEARCH_EX)
if r8:
print('8')
r9 = img.find_template(template9, 0.70, step=4, search=SEARCH_EX)
if r9:
print('9')
