串口 十进制整数的无效语法 和列表索引超出范围
2021-07-08 09:53
U
fd26
U
fd26
# Blob Detection Example
import car
green_threshold   = (99, 100, 127, 127, 127, 127)
size_threshold = 2000
a=0
datx=0
daty=0
    #for blob in img.find_blobs(green_threshold,invert=True,merge=True):
    blobs = img.find_blobs([green_threshold],invert=False,merge=True)
    if uart.any():
        dat = uart.readline().decode().strip().split(',')
        datx=int(dat[0])#机械臂x
        daty=int(dat[1])#机械臂y
        print(datx)
        print(daty)
        for b in blobs:
        if h_error<-500:
            if h_error<-1500:
                a=1
            if h_error>-1700:
                h_output=(abs(h_error))/100-3
            #print("h_output",h_output)
                if x_error>0:
                    car.run((h_output-2)*10-x_error*2,h_output*10)
                elif x_error<0:
                    car.run(h_output*10,(h_output-2)*10+x_error*2)
                    car.run(h_output*10,h_output*10)
           # print("h_utput",-h_output-x_output)
                if x_error>0:
                    car.run(100-x_error*2,100)
                elif x_error<0:
                    car.run(100,100+x_error*2)
                    car.run(100,100)
            car.run(0,0)
            time.sleep(0.001)
            if a==1:
                car.run(-99,-99)
                time.sleep(0.1)
                a=0
            if h_error>8000:
                if x_error>0:
                    car.run(-40,-20)
                elif x_error<0:
                    car.run(-20,-40)
                    car.run(-40,-40)
            elif h_error<3000:
                if x_error>0:
                    car.run(20,40)
                elif x_error<0:
                    car.run(40,20)
                    car.run(40,40)
                if x_error>5:
                    car.run(-30,30)
                elif x_error<-5:
                    car.run(30,-30)
        car.run(50,-50)
2021-07-08 18:29
I
网红小智智 星瞳科技
你print一下看看data[0]是啥,反正不是数字。
