import sensor, image, time, os, tf, uos, gc,pyb,machine
uart = UART(3,115200)
green = (10,100,-50,15,-15,50)
red = (0,100,-30,50,-30,30)
blue = (10,100,-20,40,-10,40)
orange = (10,80,-10,30,-20,35)
brown = (0,80,-10,20,-20,30)
yellow = (50,80,-10,10,-20,60)
white = (10,100,-20,30,-30,20)
gray = (20,80,-10,15,-10,25)
sensor.set_auto_gain(False)
name = 'c'
def rubbish():
net = None
labels = None
net = tf.load("trained.tflite", load_to_fb=uos.stat('trained.tflite')[6] > (gc.mem_free() - (64 * 1024)))
except Exception as e:
raise Exception(
'Failed to load "trained.tflite", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(
e) + ')')
raise Exception(
'Failed to load "labels.txt", did you copy the .tflite and labels.txt file onto the mass-storage device? (' + str(
e) + ')')
image = sensor.snapshot()
scores = net.classify(image)
for obj in net.classify(image, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
image.draw_rectangle(obj.rect())
name = predictions_list[0][0]
max = 0.8
if predictions_list[i][1] > max:
max = predictions_list[i][1]
name = predictions_list[i][0]
if name == 'KHSLJ':
name = 'k'
elif name == 'YHLJ':
name = 'y'
elif name == 'CYLJ':
name = 'c'
elif name == 'QTLJ':
name = 'q'
return name
blobs1 = img.find_blobs([green])
blobs2 = img.find_blobs([red])
blobs3 = img.find_blobs([blue])
blobs4 = img.find_blobs([orange])
blobs5 = img.find_blobs([brown])
blobs6 = img.find_blobs([yellow])
blobs7 = img.find_blobs([white])
blobs8 = img.find_blobs([gray])
if blobs1:
rubbish()
uart.write(name)
if blobs2:
rubbish()
uart.write(name)
if blobs3:
rubbish()
uart.write(name)
if blobs4:
rubbish()
uart.write(name)
if blobs5:
rubbish()
uart.write(name)
if blobs6:
rubbish()
uart.write(name)
if blobs7:
rubbish()
uart.write(name)
if blobs8:
rubbish()
uart.write(name)你把name打印出来看看是啥。
def rubbish():
net = None
labels = None
raise Exception(
e) + ')')
raise Exception(
e) + ')')
max = 0.8
if name == 'KHSLJ':
name = 'k'
name = 'y'
name = 'c'
name = 'q'
return name
name = rubbish()
if blobs1:
rubbish()
uart.write(name)
print(name)
if blobs2:
rubbish()
uart.write(name)
if blobs3:
rubbish()
uart.write(name)
if blobs4:
rubbish()
uart.write(name)
if blobs5:
rubbish()
uart.write(name)
if blobs6:
rubbish()
uart.write(name)
if blobs7:
rubbish()
uart.write(name)
if blobs8:
rubbish()
uart.write(name)前面打印name 一直是'c',我就把代码改成这样了,又提示了这个错误
tf.load不要在死循环里调用,只需要在一开始调用一次。
